Author Topic: Does the Siglent SDS2202X-E Fan Run All the Time?  (Read 451 times)
Offline cortesTopic starter
« on: July 02, 2022, 03:41:00 pm »
I just got a Siglent Technologies SDS2202X-E Oscilloscope. The fan started running right after I plugged it in. I powered it on with the front button and later powered it off. It then went through a shutdown mode. The fan is still running the next day. Is this normal?
Offline tv84
  • Country: pt
Re: Does the Siglent SDS2202X-E Fan Run All the Time?
« Reply #1 on: July 02, 2022, 04:04:06 pm »
I haven't heard Siglent got into the gyroscope world so, it sure seems something is not right.
Offline tautech
« Reply #2 on: July 02, 2022, 08:45:07 pm »
New or used ?
No, it's certainly not normal and when you reply let's work through the next steps to take.
