Which part did you soak?
The whole PCB.
I removed the LCD first - I was scared that I'd snap one or more of the clips holding the LCD to the PCB, but thankfully that didn't happen. Then I placed the PCB in the smallest plastic tub I could find that would hold it, and poured enough 99% IPA to cover the board. If I remember right, the IPA went about halfway up the input jacks. I should have thought to take photos.
And a reminder of my mistake: take the fuses out to save yourself $10-15 or so replacing ones that get filled with IPA.
Then I left it for 24 hours. I'd occasionally rock the tub to "swish" the IPA around, but I doubt that did anything. After 24 hours, I took the PCB out , sat it down next to a small fan blowing on it for a day, flipping the PCB over occasionally. I think it was less than 24 hours drying before I got impatient and reassembled and tested it.
I'm still surprised it worked. There was absolutely no visible change that I noticed (other than the fuses, which went from white to a dingy light brown color from IPA seeping in).
