Hi
I'm using an 37347C and I'm wondering what this connector is? Ultimately, I'd like SMA M.
The datasheet says it's Universal K (male) which I learned is 2.92mm and also the shares the same pin as SMA. However, I don't think it's a good idea to screw an SMA F in there, is it? Is there a bulkhead adapter that would protect the instrument's connector and allow me to connect an SMA M cable to it safely?
Thank you for the advice!!
