Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
U1272A - Yay!
« previous
next »
Print
Search
Pages:
Prev
1
2
3
All
Go Down
Author
Topic: U1272A - Yay! (Read 30332 times)
zaoka
Frequent Contributor
Country:
Re: U1272A - Yay!
Reply #50 on:
September 21, 2011, 12:03:43 pm »
Just got one of these from ebay (open box), everything work perfect except ZLOW, with no test leads it shows 6.5V AC, DC is 0V...
They should install display with better contrast (its to dark) and make that switch have better feel (like old Triplett meters
Logged
Kiriakos-GR
Super Contributor
Country:
User is banned.
Re: U1272A - Yay!
Reply #51 on:
September 21, 2011, 03:05:49 pm »
Z-Low defaults at the range 1000V AC .... in this range there an indication of 4.7V in my unit.
The True RMS IC controller cause a minimum leak.
Some manufacturers compensate this minimum leak with software tricks, some others do not.
The Fluke 28II reads 2V ( 1000 ACV range) and by it self it zero out this reading in 5-8 seconds.
Last Edit: September 22, 2011, 01:57:57 am by Kiriakos-GR
Logged
PetrosA
Country:
Re: U1272A - Yay!
Reply #52 on:
September 22, 2011, 12:05:37 am »
Mine shows 7.5-8.5V in ZLow mode. Like Kiriakos said, it's because it uses the 1000V scale and doesn't do correction. Once you connect it to a voltage source, it will read correctly. Nulling mine seems to introduce offset error.
Logged
I miss my home I miss my porch, porch
Print
Search
Pages:
Prev
1
2
3
All
Go Up
« previous
next »
Products
Test Equipment
U1272A - Yay!
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
