I bought a cheap Fluke 123 scopemeter from ebay with lines on the screen and a flat battery. No problem I thought, I can live with the lines and I will just get a new 3rd party battery for £15 from Amazon here in the UK.
This is where all the fun and games starts!
The original Fluke battery is a BP120 and is a 2000mAh NiCd unit. It would not charge in the scopemeter and would only maintain the unit for 30 second or so before it powered down.
The new replacement battery is made by Cameron Sino and is a BP130 Equivalent 3000mAh NiMh unit.
But on comparing the wiring on the 6 pin connector for the two batteries the new 3000mAh one is wired wrong and will not work at all in the scopemeter. As it was low cost and not worth the hassle of changing it. I have investigated further and resolved all of the problems with it.
This is the correct pin wiring for the scopemeter battery connector.
Pin 1 Not Connected
Pin 2 +
Pin 3 -
Pin 4 I Identification (0 Ohms=NiCd) (825 Ohms=NiMh) Return on Pin 3
Pin 5 Not Connected
Pin 6 T Temperature Sensor (NTC Resistor) Return on Pin 3
So I swapped the connector pins round in the plug on the new battery and then the meter would power on with it. But it still would not charge fully or perform a battery refresh operation.
After a bit of Googling and a look at the Fluke service manual I found the above pinout information and I also discovered the correct resistance value for the NiMh battery.
I measured the value on my battery Identification resistor and I got a resistance of 0.8301 Meg Ohms not the 825 Ohms it is supposed to be. So the manufacturer not only wired the plug wrong they also compounded the problem by putting the wrong resistance value in as well!
So I have now cut open the heat shrink and corrected their mistakes as you can see in the pictures below.
Battery
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123001Large_zpsfbbd29d4.jpg)
Original and pending replacement resistor
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123004Large_zps118c2252.jpg)
Crap insulation on the opposite side of the original resistor
Removed resistance value
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123020Large_zps59516f3c.jpg)
Replacement Resistance Value
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123021Large_zpse9da57bd.jpg)
Correct Plug wiring
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123008Large_zpseceff81d.jpg)
Repaired and heatshrink added for a slightly better insulation
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123014Large_zps92269826.jpg)
Red insulation tape as I have run out of larger heatshrink. This may get replaced in future if I can be bothered!
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123016Large_zps81c77d6a.jpg)
Original Battery pack
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123034Large_zps77ad9ee5.jpg)
Refresh now detects the NiMh and changes from 12 (NiCd) to 19 Hours! Result.
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123031Large_zps9f5ccfc1.jpg)
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123032Large_zpsb7e2a0de.jpg)
![](http://i699.photobucket.com/albums/vv357/cones_stuff/Fluke%20Scopemeter%20123/FlukeScopemeter123029Large_zps883ca00f.jpg)
