Author Topic: HP54503A dont work  (Read 8641 times)
Offline venuscubeTopic starter
HP54503A dont work
« on: August 02, 2013, 01:23:21 am »
I bought a HP 54503A last year, it worked perfect at the beginning. It haven't been used for a few month. Yesterday I tried to turn on it but it didn't work at all :(
The fan is running and I can hear a click sound when turn on the power. But the screen has nothing on. Tested with meter I saw the VCC voltage on the TTL chips is OK. What is the possible problem according to you experts? Can the failure of the NVRAM cause such problem? many thanks
Offline free_electron
    • SiliconValleyGarage
Re: HP54503A dont work
« Reply #1 on: August 02, 2013, 02:27:54 am »
does it smell like cat-wee  ? ( no seriously . does it smell like cat-wee .. ) these machines suffer from bad caps in the power supply...
« Reply #2 on: August 02, 2013, 02:35:32 am »
oppps.. really, my colleague asked my why the room has a strange smell, like burning paper.
« Reply #3 on: August 02, 2013, 03:05:04 am »
bingo.
easy to fix. pop cover off machine. the power cartridge has a large ribbon cable. unplug that , slide cartridge out. take cover off cartridge. use facial proboscis ( nose) to locate the stinkers and swap em. clean the goop off the board as it is corrosive.
« Reply #4 on: August 02, 2013, 03:10:29 am »
openned..but haven't found any cap looks bad. Metering now
Offline MetraCollector
  • Country: cz
« Reply #5 on: August 02, 2013, 08:51:51 am »
Gentlemen, I have bought 54503A too, month ago at Friedrichshafen HAM. I saw 500MHz label and 4 channels and higher number, so I thought I'd replace my 54502A. Then I discovered it has much more worse parameters than 502A. :palm:
Anyway, the scope worked for a while. One next time I switched on and nothing happened. I intuitively swapped PSU and it worked.
So, could you please tell me, WHICH of caps are usual to go wrong ? Every of them looks alright, no smell and no visible damage.
Thank you
« Reply #6 on: August 02, 2013, 01:36:20 pm »
Typically the ones in the low voltage section. They are either blue or orange if i remebe correctly.
Offline ddavidebor
    • Smartbox AT
HP54503A dont work
« Reply #7 on: August 02, 2013, 01:43:26 pm »
Check the iec filter.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
« Reply #8 on: August 06, 2013, 12:51:55 am »
Can IEC filter cause such problem? the PSU is working and the voltages seems to be right. Now the screen looks like this.
What will cause such problem?
« Reply #9 on: August 06, 2013, 01:19:16 am »
Thank you
Can you pls tell me where to get a PSU?
Offline Stonent
« Reply #10 on: August 06, 2013, 02:32:22 am »
A screen like that could be no signal or too much.
« Reply #11 on: August 06, 2013, 03:35:05 am »
monitor is on but the scope mainboard is not running
Offline Jwalling
  • This is work?
« Reply #12 on: August 06, 2013, 01:20:12 pm »
Yes, those series of scopes won't complete boot if the NVRAM battery dies. I forget if that particular model has a Dallas type part or a lithium battery. All the 545XX scopes right up to the 54542A/C will fail to boot when the battery dies.
Jay
Jay
System error. Strike any user to continue.
Offline ddavidebor
    • Smartbox AT
« Reply #13 on: August 06, 2013, 06:40:20 pm »
that's wrong they boot and show "cal error"
you should check the various power rail on the power supply, they're accessible without any throuble on an extra connector in the middle.
if you need nvram or main filter i've one
  • Country: cz
« Reply #14 on: October 13, 2013, 12:21:29 pm »
Greetings, I finally put this machine on my bench yesterday and took leads in hand.
When I turn on the PSU, I hear some click and then I hear periodic very weak click (that small relay ?). When I turn it off, I hear two clicks, very similar to locust sound. ;D
Voltages are shown in the picture. +12V and -12V branches act very similar, voltage is varrying from 8V to 11V in about 2Hz.
Voltages in brackets are the ones written in service manual.
Could you please tell me what it is supposed to be wrong ? Is it definitely electrolytics fault ? The reason I am asking this is that I don't have the values of elyts available in my home stock. :( (especially lowESR).
Thank you
« Last Edit: October 13, 2013, 12:23:42 pm by MetraCollector »
Offline willb
« Reply #15 on: October 13, 2013, 12:59:50 pm »
I'd check those organge Sprague caps first (that's what they look like anyway). Pretty much every HP machine I bought broken off eBay which had these orange Sprague caps were bad.
My 6034L has +15V and -12V rails, which both had bad orange Sprague's, and the rails behaved in a very similar fashion as yours...
« Last Edit: October 13, 2013, 01:03:29 pm by willb »
Offline Shock
« Reply #16 on: October 13, 2013, 01:57:33 pm »
There has been more oscilloscopes fixed by replacing the input filter caps on this forum than Daves rooftop solar panels.
  • Country: cz
« Reply #17 on: January 17, 2014, 07:22:48 pm »
Hello again.
I put it on the workbench again with my colleague and checked EVERY electrolytic cap (desoldered) on LCR and every of them is in perfect condition. Even changing caps doesn't make a difference.
Any hint what else I should look for ?
Thank you.
« Last Edit: January 17, 2014, 07:25:58 pm by MetraCollector »
Offline KJDS
    • my website holding page
« Reply #18 on: January 17, 2014, 07:33:53 pm »
When you tested the supply, did you have a load on each rail?
  • Country: cz
« Reply #19 on: January 17, 2014, 08:43:52 pm »
Yes, I had. No difference too. :(
  • Country: cz
« Reply #20 on: January 18, 2014, 05:13:36 pm »
And another problem is one of the four attenuators. Sometimes it switches, sometimes not.
Any hint about repairing that relay ? Is it safe to desolder it from ceramics ?
