fwiw a properly working 8060A still kicks serious goals today,
I've often wondered if a re-issue of the 8060A would sell today...
If anyone does not need a or another bench meter, as the 8060A can be also powered without batteries bench style anyway =
An 8060A Mk2 might be a goer as it is, same everything including the dual fused 2 amp current mode (no added 10A/20A BBQ mode please)
but I would lose the bulky switches on the side, and put a bank of (same layout) covered membrane switches or whatever Fluke have kicking around, like on the 87V meters etc (with hold down startup options),
so the meter could be made 'adverse conditions' resistant
..and rolled in sand for the revisited photo shoot demonstrating Fluke reliability,
so it's believable this time around > with the leads attached please..
Perhaps a simple backlight chucked in,
and if they don't up the CAT, they should at least supply FUSED LEADS to avoid an input re-design
so it can do decent CAT 111 and maybe a 300/500 volt CAT4
and in 2020 it's got to have a holster to toughen it up,
a better fit than my DIY knockup ones, which do ok and better than nothing
fwiw the yellow is an older Jaycar generic holster
and the red one (and leads) salvaged from a 'hey keep it or toss it mate' half DOA new Brymen,
after a replacement sent asap by an excellent local Ebay seller
and lets not forget the
metal threaded screw posts this time, no tacky crumblers!
