Author Topic: Multimeter software that workes with many brands?  (Read 11658 times)
Offline XOIIOTopic starter
« on: May 08, 2014, 01:57:08 am »
Hey all, I had noted it somewhere and promptly forgot, but I recall seeing several times a free bit of software for interfacing with all types of data logging multimeters, what is it?
Offline PedroDaGr8
  • A sociable geek chemist
Re: Multimeter software that workes with many brands?
« Reply #1 on: May 08, 2014, 02:31:39 am »
UltraDMM?
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
« Reply #2 on: May 08, 2014, 02:38:20 am »
UltraDMM?
Bingo, thanks. Knew I'd recognize it when someone said it.
Offline Wytnucls
« Reply #3 on: May 08, 2014, 02:39:51 am »
UltraDMM doesn't work with the UT71 series.
This one perhaps:
http://sigrok.org/wiki/Supported_hardware#Multimeters
« Reply #4 on: May 08, 2014, 02:50:55 am »
This one perhaps:
Yeah figured that out  :-\
I'm looking for one that might datalog a bit better or have a better live graph, the UNI-T software is fine, but excel says it is not in that file format yet it saves it as that.
That software shows it as "in progress" so I suppose it will come on an update.
I also need to maybe get a bus pirate or something, there is a small 2x4 pin header layout that I wonder if it might be for programming, if I could read the firmware and maybe tell it that it is the UT71D I could get the 10k data logging points instead of a measly hundred. It would be sweet to have that for offline and I bet that it is the exact same board as the UT71D
Offline Wytnucls
« Reply #5 on: May 08, 2014, 04:48:42 am »
The CMOS serial EEPROM is the same on the B and D models (512K I2C). The C and E models probably use the same chip.
It should be possible to release all the memory through software.
« Reply #6 on: May 08, 2014, 05:27:40 am »
I was thinking the UT71C and D would be the same, since the E ads power monitoring with an adapter and I think another mode.
I'm having troubling finding an eeprom chip, so far just a couple op amps, voltage references, and ram for the LCD. Once of those LCD ram chips has a sticker with C written on it so maybe it also works to hold the cal data.
« Reply #7 on: May 08, 2014, 05:29:52 am »
Wait, found it! 24lc515h! http://ww1.microchip.com/downloads/en/DeviceDoc/21673E.pdf Tis the same beast!
Offline zapta
« Reply #8 on: May 08, 2014, 05:59:38 am »
Kst is very useful for drawing live graphs.
Sent from my Nexus 5 using Tapatalk
Offline Wytnucls
« Reply #9 on: May 08, 2014, 06:12:33 am »
Here is the layout on my 71D:
« Reply #10 on: May 08, 2014, 06:20:13 am »
Basically identical to mine in the thread over here: https://www.eevblog.com/forum/testgear/hacking-the-uni-t-ut71c-(wipneed-help)/
Can you dump the rom to a file? (and if so give me instructions/the tools needed to do so?)
Obviously the sticker with C on mine is not cal data, but just the model number for when they are putting them together. Do you think changing the rom will mess up cal data?
Offline Wytnucls
« Reply #11 on: May 08, 2014, 07:43:39 am »
Sorry, I don't have the tools or the skills to extract the ROM file.
I wouldn't fiddle with it too much. Enjoy the meter for what it does. Internal data capture is just a small part of its capabilities.
« Reply #12 on: May 08, 2014, 03:19:19 pm »
Yeah, true enough but being able to datalog every second for almost 7 days would be awesome.
Offline Wytnucls
« Reply #13 on: May 08, 2014, 03:23:41 pm »
The 9V battery won't last much longer than 3 days.
Offline danb35
« Reply #14 on: May 08, 2014, 03:31:07 pm »
Another piece of free and open source software that supports a bunch of DMMs is QtDMM (http://www.mtoussaint.de/qtdmm.html).  It runs under *nix and MacOS; not sure about Windows.
« Reply #15 on: May 08, 2014, 04:04:48 pm »
You could always just hook up a power supply.
Offline linux-works
    • netstuff
« Reply #16 on: May 08, 2014, 04:36:34 pm »
I used qtdmm on the vichy cheapie dmm:
I think I also was able to use qtdmm with some of the old radio shack rs232 meters.
« Last Edit: May 08, 2014, 04:39:19 pm by linux-works »
