I guess I should have filmed it during the reboot.
It seems to be working OK but I was quite alarmed when it gave that message with 'fatal error' included.
This message was on the camera screen and not the PC.
Maybe the next person to do this should film the reboot sequence in case it happens to someone else too.
No Flir tools came with the camera and I downloaded these from Flir and installed them. Was this correct?
I also zipped the flashfs folder tree with the camera.cmd file included outside the folder. Was this correct?
I put the CRC in exactly as per the screen. i.e. the letters displayed in the check were lower case and I entered them as per the instructions with CRC in uppercase but I used lower case for the actual letters inside the CRC because this is how it appeared on the PC screen. Was this correct?
I think the mod instructions need a fair bit of work if this mod goes mainstream because some people will get confused (more than me?). A video 'howto' would be the best method to show how to do it or failing this a decent word doc with screenshots of every stage
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
