I'm doing the tests on two different computers running windows 8.1, so far I get the same results.
My network is running DHCP at 192.168.102.1, all computers and devices are getting adresses from the DHCP (192.168.102.range 150-250)
Ok, so I assigned the FLIR NIC at 192.168.0.1 subnet 255.255.255.0... nothing else. When I plug the camera in, the window at the lower right reports
"camera at IP address 192.168.0.2"If I open FlirInstallNet it reports 192.168.0.2 / Flir USB Video
using ipconfig /all:
Computer IP: 192.168.102.181 subnet 255.255.255.0 (autoconfig: yes DHCP: yes)
Flir IP: 192.168.0.1 subnet 255.255.255.0 (autoconfig: yes DHCP: no)
Results: using Joc-C's program I get "telnet failed" but UVC (video) works + Internet connection works
deactivating computer NIC.... program works in every mode !! I seems the computer's NIC blocks the RNDIS path somehow.
Thank-you for helping me out, I greatly appreciate it.
I will continue trying different configs. I hate windows networking.
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
These computers are laptops using Wifi. I will try a Ethernet wired connection on another computer today...
Thanks again !
