Author Topic: Where Can a Guy Find a Low Tolerance Inductor as a Standard?  (Read 2700 times)
Offline TheRuler8510Topic starter
  • RF Engineer
Where Can a Guy Find a Low Tolerance Inductor?
I have good and cheap capacitance standards, like 0.05% tolerance, and resistors at 0.01%, but I can't seem to find an inductor for less than $60.
Any suggestions? The cheapest currently on eBay are $60 and don't even quote a tolerance.
Thanks,
"There are no facts, only interpretations."
--Friederich Nietzsche
Offline HighVoltage
Re: Where Can a Guy Find a Low Tolerance Inductor as a Standard?
« Reply #1 on: May 28, 2015, 12:42:21 pm »
There are some on ebay from time to time, but they usually start at $400
I had the same challenge a few years back and I made my own.
Bought a few temperature stable toroidal cores and wounded them myself with good quality insulated copper wire.
Then I had then certified at a calibration lab.
They turned out to be extremely stable in regards to inductance, even with changing temperatures.
Using a toroidal core is the only way, that I found to get them stable and this way, you can even mount
the inductor in an aluminum housing, without influencing the inductance at all.
Offline SArepairman
  • wannabee bit hunter
« Reply #2 on: May 28, 2015, 04:01:35 pm »
how many ppm TCL (temp co induc) did you get with this home technology
« Last Edit: May 28, 2015, 04:03:16 pm by SArepairman »
Offline owiecc
    • Google scholar profile
« Reply #3 on: May 28, 2015, 06:13:37 pm »
I can help with a Keysight E4990A if anyone wants to test their inductor.
Offline HighVoltage
« Reply #4 on: May 29, 2015, 11:09:08 am »
Hello owiecc,
I would take you up on the offer.
PM sent, Thank you.
  • RF Engineer
« Reply #5 on: May 30, 2015, 09:04:42 pm »
Hello too, owiecc.
I would also like to take you up on your offer. I'll send a message.
Regards,
