Author Topic: FLIR e4 resolution upgrade  (Read 2902 times)
Offline sinbadTopic starter
« on: March 07, 2015, 11:27:01 am »
Hi,  I'm trying to upgrade the resolution of the e4 following the instructions found on this site but am unable to get ftp access. Have set to RNDIS. The next stage is to connect via ftp. However there is no IP address of 192.168.0.1 or gateway 192.168.0.2 to connect to and using filezilla it just times out. Any help appreciated
Offline tmbinc
Re: FLIR e4 resolution upgrade
« Reply #1 on: March 07, 2015, 01:07:22 pm »
- Make sure the device is set to RNDIS+UVC or RNDIS (seems you already did that)
- Make sure you have installed the Flir device driver. (Otherwise it doesn't detect the USB device as a RNDIS, but Serial port).
- The IP address can be 192.168.0.2 or 192.168.250.2; I don't know how the cam decides on its address.
- Auto configuration never worked for me, so I had to manually set 192.168.250.1 as the local IP address. Use 255.255.255.0 as the network mask, and don't set a gateway or DNS.
Make sure the cam can be ping'ed. ("ping 192.168.250.2" for example). Only if that works try to connect with an FTP client.
(FYI "Gateway" doesn't matter; the cam does not provide internet. 192.168.x.2 isn't the gateway IP address, but the IP address of the cam.)
Offline JIMMYZ
« Reply #2 on: May 24, 2015, 01:19:40 am »
HI ALL,
    INSTALL OF UPGRADE TO A 2.3.0 CAM SEEMED FINE, UNTIL I GET ECCONREFUSED WHEN TRYING TO CONNECT.  I CAN PING THE CAM,  WHAT AM I MISSING?   THANKS IN ADVANCE,   JIMMYZ
Offline Skimask
« Reply #3 on: May 24, 2015, 03:20:42 am »
A single press of the caps lock button
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline JIMMYZ
« Reply #4 on: May 30, 2015, 09:59:10 pm »
 Thanks for the tip skimask,  Sorry to offend with the c-lock.
my network guy says everything looks like it does  in the fubar guide,  until filezilla produces the "ecconrefused error"
can ping at will.
any ideas help
thx jimmy
