Author Topic: Flir E30 config and wlan  (Read 7908 times)
Offline reallybigone916Topic starter
  • I'm Jimmy and Jerry
« on: July 30, 2015, 04:48:12 am »
1. On the digital camera, Is there a hardware difference between the E40-E60 and E30 .
The Flir spec sheet indicate 2MB on the E30 and 3.1MB for the E40-E60.
2. What's the biggest SD card you can use?
Thank you.
« Last Edit: August 11, 2015, 09:23:04 am by reallybigone916 »
Re: Flir E30 config and specs
« Reply #1 on: August 09, 2015, 01:48:56 am »
Just upgraded my E30 using "E60 goodies" files.
Everything is good except my Wi-Fi connection.  I can't connect to a network.
Anyone with the similar problem?
Offline tomas123
« Reply #2 on: August 09, 2015, 02:09:46 pm »
please post the first digits of your serial number
« Reply #3 on: August 09, 2015, 04:46:48 pm »
It's a 49xxxxxx
Offline tomas123
« Reply #4 on: August 09, 2015, 09:16:44 pm »
see
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg561266/#msg561266
Upgrading E30 to E8 including resolution upgrade.
Hello All,
   My name is Gustavo, and I have been craving to share with you all a great accomplishment I had with an E30, I successfully upgraded  it to an E60, using all the available hardwares, including “Camera”, Flash Light for illumination, 320x240 resolution with full frame buffer, WiFi, Bluetooth,  Video Recording, and even the name of it is E60 instead.
...   1. This hack was performed over an E30 2012 model, so, before changing your unit,  check your unit serial number, it has to start with 490.
« Reply #5 on: August 10, 2015, 01:38:19 am »
Did all of that.  |O
The problem I have is not able to see my wifi (or see other wifi) or Bluetooth.
Please see my attached files
« Last Edit: August 10, 2015, 03:37:36 pm by reallybigone916 »
Offline tomas123
Re: Flir E30 config and wlan
« Reply #6 on: August 11, 2015, 03:13:05 pm »
do you have a WiFi menu?
« Reply #7 on: August 11, 2015, 03:40:49 pm »
yes, both wifi and bluetooth
Online Pinkus
« Reply #8 on: August 11, 2015, 09:53:40 pm »
there are E30 with Wifi- and bluetooth-hardware and there are E30 where these daughter boards are missing. It seems you got one without the needed hardware. Sorry  :-[
« Reply #9 on: August 12, 2015, 01:50:44 am »
 :-[ :-[ :-[ :o :o   why would they do such a thing???
Apparently Flir made two versions. 49001-1801 (with digital cam) and 49001-1601 (without digital cam).
Mine is the 49001-1801 (made in 2013).
« Last Edit: August 12, 2015, 06:50:39 am by reallybigone916 »
« Reply #10 on: August 12, 2015, 06:56:28 am »
Found the answer to my original post.
 Just remove line below to get the full 3.1MP
FlashFS\system\appcore.d\config.d
.caps.config.image.settings.resVIS int32 1600
Online Pinkus
« Reply #11 on: August 12, 2015, 07:27:47 am »
Because, due to the datasheet, the E30 did not come with Wifi and Bluetooth. Thus I suppose Flir were producing E30 without this (unneeded) hardware mounted to have lower BOM.
As some E30 does have this hardware (kind of lottery for the buyer as you can't check), I assume that they were using either E40/E60 boards to produce E30s when they did not have stock of E30 boards or that they at one point decided to produce and mount only one board for all Exx.
« Reply #12 on: August 12, 2015, 09:59:36 am »
I'll do some digging into admin menu, under Browse Resources. You can actually see and confirm all your setting\status and config setting from there.
« Reply #13 on: August 13, 2015, 03:04:09 am »
Please can anyone compare my HW profile to their E30 (with wlan). I would like to put this wlan "issue" to bed.  :-+
Offline tomas123
« Reply #14 on: August 13, 2015, 09:42:26 am »
E40 model 2012
Offline hikanio
« Reply #15 on: May 22, 2016, 10:38:12 am »
Hmm... has anybody tried to input the "missing" slbwver hw component in the EEPROM menu? Just to make sure that it is really physically missing....
Copied from other thread:
https://www.eevblog.com/forum/thermal-imaging/flir-e40-upgrade-configuration/msg946257/#msg946257
How to find out, if my E30 49001-1801 is physically missing it's wlan/bluetooth modul?
As far as I understood from other postings is the absence of the hw component "slbwver" the indicator that something is missing.
In my service menu I can see that instead of any Part #, revision # and Serial # there is only an asterisk "*" in the slbwver row.
But... in he EEPROM Menu you can actually set these components manually so the absence of the slbwver data is not enough proof for me that this component is physically absent.
In theory it might be just not enabled. (Yeah I know, whishful thinking, but the hope dies last ;-) )
Has anybody played around with these settings yet?
Cheers
Hikanio
Offline Zucca
  • EE meid in Itali
« Reply #16 on: March 12, 2018, 01:34:53 pm »
I got my hands on a E30
SN 490217XX
PN 49001-1801
SW 1.36.23
Model E30_B 1.1
This units has the WIFI/Bluethoot. When BT is on the Mobile finds the E30 camera, I have no inormation about WIFI but I assume the Radio board is there.
So I can not confirm this:
https://www.eevblog.com/forum/thermal-imaging/flir-e40-upgrade-configuration/msg988381/#msg988381
This unit with PN 49001-1801 has the wifi board, SN is 490217xx. So maybe the theory SN 490xxxxx has the WIFI is correct.
Now I am waiting for another E30 (Model should be 49001-1601), keep you posted if it will have the Radio Board on it.
« Last Edit: March 12, 2018, 02:18:58 pm by zucca »
Offline Zucca
  • EE meid in Itali
« Reply #17 on: March 12, 2018, 01:57:43 pm »
What exactely has the 49001-1801 more than the 49001-1601? "Fusion"?
Offline Zucca
  • EE meid in Itali
« Reply #18 on: March 12, 2018, 01:58:43 pm »
I will investigate on mine and report.
Offline Zucca
  • EE meid in Itali
« Reply #19 on: March 22, 2018, 01:24:47 pm »
