So I went to a local fleamarket this morning, since you never know what you find.
Most is garbage but sometimes there are little gems to be found.
Anyway there was not much to be found since it was not an electronics fleamarket but then I stumbled upon this resistor decadebank which has a beautifull wooden enclosure and these great knobs you dreamt of when you were young.
For a few euro's to a good cause I could not resist taking it home, I guess i have a bit of a hoarder virus but luckily not the worst one
At home I first looked up the unknown manufacturer: dr C.E.Bleeker, Zeist Holland.
Not very much information to be found but in a
brief online dutch biography you can see it was a woman.
That is a surprise a female PhD in electronics/optics in the 30s that is very special. She created the business early 30s with precision instruments and she esp. became succesfull with the phase contrast microscope.
End of the 60s the company was taken over and 1978 was closed.
Nice some piece of bygone history, back to the resistors
It still looks amazingly good, few scratches on the wood, almost none on the black metal surface, this thing has been hardly used.
From the high serial number 57456 i guess it is probably from the 1960s.
So what will be inside, the standard rotary switches with a lot of resistors probably but there is only one way to find out, as Dave always says: take it apart
