I'm currently working on a 4-20mAmp sensor system, so to test this I wondered if I could get a piece of kit that would emit a 4-20mAmp signal, maybe in a standard wave form like a sine wave or something, but with very long period. I'm taking a sample every one or two minutes so given that sampling rate some formula, can't remember which, would dictate the frequency of the signal that I'd recognise as what I was expecting.
Maybe given that really low frequency the easiest thing to do would be to rig up a circuit to a micro controller that could output a current. Seem to remember an early eev blog video on creating a current sensor. Not exactly calibrated but maybe?
I'm embedded SW so have limited experience of test gear, (can just about use a scope ;-) so maybe a basic signal generator can do this. My only issue might be that I'm going to leave the unit on for a soak test of weeks duration.
