come across one of these locally Agilent 54624a ?
It is a really nice scope. The A stands for Analog and means it does not have logic analyzer input. If you can get the 54622D is better (it is a Mixed Storage Oscilloscope with 2+16 channels). Dave reviewed it in one of his videos. Is it worth buying it? Depend on the price you pay. The 54622D are priced around $250 in the US
It was a great scope in the day. It started mixed signal craze..
On the other hand, that scope has maximum real-time sample rate of 200 MS/sec, meaning that it's maximum sample rate is worse than DS1000Z with all four channels on, when DS1000Z is sampling with 250 MS/sec. With all channels sampling it has maximum sample rate of 100 MS/sec and in both cases it doesn't really comply to Nyquist criteria.
To work around that, it does repetitive sampling, and behaves like a classic sampling scope, creating one screen from many repetitive triggers.
That means that if you are looking at stable, clean, repetitive signal (like from a stable clock source, or crystal or such) you will get nice oscillogram of that.
If you want to take a look at nonrepetitive signal (some kind of burst, series of packets on a digital bus) you wont be able to see it. You will see scrambled crap..
Worst part is that if you have some signal that is supposed to be nice, clean and repetitive, but has a problem in it (like optical encoder that produces random glitches in output) you won't see any of that.
So if you want to use that scope for anything less than 30ish MHz (and that includes all harmonic content of the signal) and use it more like an analog scope, it's great. You will be able to get nice single capture of slow signals.
Even crappy little DS1000Z has better triggering, better sample rate (to capture faster events) more memory. And it is bottom of the barrel.
But, hey, to each its own..
OTOH, 54641A/D and 54642A/D are much, much better machines. They are great, if you can get on that works well, and costs right.
