Author Topic: first time buyers oscilloscope analysis paralysis help!!!!!  (Read 15266 times)
Offline njkmontyTopic starter
« on: September 10, 2019, 09:40:24 am »
after asking questions, reading , watching , reading some more, I thought i had come to a decision.
Rigol Ds1054z
or
Siglent SDS1202X-E
i really dont think i will need a 4 probe model , however good UI
nice big crisp screen, fast response as possible for that price.
But i really also only envisage doing basic stuff,
 measure power supply regulation
biasing bbd chips in effects pedals
biasing clocks in effects pedals
working on valve amps
no real digital requirements come to mind
i dont really want to spend much more than the above , and prefer to buy a reputable brand.
is there a different model within these brands that ticks my boxes?
or do all of these scopes have all this extra stuff i probably wont use?
i dont want to buy a second hand analogue
just need someone to push me over the edge?
sorry for the gazilianth scope question!
Re: first time buyers oscilloscope analysis paralysis help!!!!!
« Reply #1 on: September 10, 2019, 10:49:21 am »
 :clap:
Yep, get a DSO but this:
Of that you can be reasonably sure for some time until your skills develop.
SDS1202X-E is a great little scope and my best seller still. You won't be disappointed with its feature set or performance.
The following users thanked this post: queennikki1972
Online Fungus
« Reply #2 on: September 10, 2019, 11:24:49 am »
GW-Instek GDS1054B is good for audio work.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #3 on: September 10, 2019, 11:27:34 am »
 :popcorn:  >:D
« Reply #4 on: September 10, 2019, 11:30:03 am »
i gather this is a daily occurrence?  :)
 how is the GDS1054B  better for audio work?   from what i can tell its specs arent as good as the siglent?  or am i missing something
Online Fungus
« Reply #5 on: September 10, 2019, 11:30:42 am »
"Best seller" out of a list of how many? Do you even stock the Rigol DS1054Z?  :popcorn:
:popcorn:  >:D
« Reply #6 on: September 10, 2019, 11:31:52 am »
Not daily but we live for it !  :-DD
« Reply #7 on: September 10, 2019, 11:32:40 am »
is there anyone here who doesn't have a financial interest in their advice?
« Reply #8 on: September 10, 2019, 11:33:16 am »
Nope, I turned Rigol down when they came knocking.  :P
« Reply #9 on: September 10, 2019, 11:34:03 am »
Plainly visible in my profile.
The following users thanked this post: BillyD
« Reply #10 on: September 10, 2019, 11:34:45 am »
yes it is
« Reply #11 on: September 10, 2019, 11:36:10 am »
what scope would you recommend if it wasnt in your respective portfolios?
Online Fungus
« Reply #12 on: September 10, 2019, 11:38:43 am »
The input circuits are very nicely designed, analog-wise. Good amplifiers and good noise levels.
It also has a much nicer UI. Faster to navigate, and with a separate button for menu selections (instead of pushing a twisty knob).
Neither of those things appear on spec sheets, believe it or not.
« Last Edit: September 10, 2019, 11:43:23 am by Fungus »
« Reply #13 on: September 10, 2019, 11:45:10 am »
There is very good reason why I stock SDS1202X-E and SDS1104X-E primarily for buyers like yourself.
From the Siglent stable I could choose a number of other models to stock but purposely don't as they don't offer the same bang for buck as the above do.
I will say hand on heart that you'd probably never need to buy anything else, such is the run my customers get with them.
« Reply #14 on: September 10, 2019, 11:48:32 am »
Can you put your hand on your heart Fungus?
or should i keep mine on my wallet!
well bugger me Im still on the fence!
Offline nctnico
« Reply #15 on: September 10, 2019, 11:51:10 am »
It has input filtering so you can filter away excess noise. OTOH the Siglent oscilloscopes have high-res which is a fixed bandwidth filter. In the end the hardware of the GDS1054B is pretty much the same as the Siglent oscilloscopes mentioned. In the end it basically comes down to price & local availability. Another oscilloscope you could throw into the mix is the MicSig TO1072. This should be in the same price bracket. This is touch-screen only and it has a battery so besides bench use it is also portable.
« Last Edit: September 10, 2019, 11:54:11 am by nctnico »
The following users thanked this post: njkmonty
« Reply #16 on: September 10, 2019, 11:53:08 am »
nctnico
  • Country: tr
« Reply #17 on: September 10, 2019, 11:55:09 am »
You definitely want one you can float with ease. Scopes that run on batteries float. A MicSig TO1152 for example.
https://www.ebay.com/sch/i.html?_nkw=micsig+to1152&_sop=15
Online Fungus
« Reply #18 on: September 10, 2019, 12:05:22 pm »
That's because you don't own one yet.  :popcorn:
...and (b) That doesn't mean a more expensive one wouldn't be much better for a beginner. It's not all about tick boxes on spec sheets, the UI layout can make basic information easier/faster to find and different models can show more information, more clearly, on screen.
eg. Do you want your measurements shown as nondescript numbers at the bottom of the screen or overlaid on the traces, like this?
Scopes that do that are more expensive but they can certainly help beginners to use basic functions.   :popcorn:
Another example: The Rigol DS1054Z has a row of buttons down the left side for turning on measurements. Push a button, the measurement appears. The Siglents make you go through a bunch of popup windows and require a lot of twisting of the multi function knob to do the same thing.
The Keysight 1000X series is the king of the "stuff that isn't on spec sheets" in the sub-$1000 bracket. It's Dave's favorite daily-use 'scope and easily worth the $150 price difference over the Siglent if you have the budget.
« Last Edit: September 10, 2019, 12:11:04 pm by Fungus »
The following users thanked this post: Keysight DanielBogdanoff
Online Fungus
« Reply #19 on: September 10, 2019, 12:08:24 pm »
Don't expect to come away with a clear answer...  this is a nest of hornets.  >:D
Offline nctnico
« Reply #20 on: September 10, 2019, 12:09:37 pm »
Please don't float an oscilloscope. You can still touch the metal parts and get a lethal shock. The only good way to measure high voltages is by using a high voltage probe or a differential probe. These aren't extremely expensive nowadays.
The following users thanked this post: BillB
Offline Mr. Scram
  • Display aficionado
« Reply #21 on: September 10, 2019, 12:11:38 pm »
Oh look. Another Siglent versus Rigol versus GW-Instek with the exact damned same usual suspects.  :--
The following users thanked this post: Gandalf_Sr, tooki
« Reply #22 on: September 10, 2019, 12:13:48 pm »
yep!
what im looking for is a similar experience to the following.
i previously had a $100 dmm
then after a while i thought bugger it i will save up for a better one,
after doing the same procrastinating fence sitting research i bought a fluke 87v
from that experienced i was amazed just using the continuity tested how nice and fast it was to use.
now i feel i dont need to look again for another dmm.
its not the most expensive available, and i enjoy using it.
Im looking for the equivilent experience now with a scope,   im just trying to find my "FLuke"
is the keysight worth aiming for ?  or am i just entering the endless staircase of upsales?
Online Fungus
« Reply #23 on: September 10, 2019, 12:15:45 pm »
Yep. Always float the device under test. You don't want lethal voltages appearing on your 'scope's BNC input connectors (or, by extension, the clips on the ends of your oscilloscope probes).
Online Fungus
« Reply #24 on: September 10, 2019, 12:17:00 pm »
Definitely, 100%, yes!
(and that's the information you should have given at the start...)
« Last Edit: September 10, 2019, 12:28:46 pm by Fungus »
