I have an RTB2004 and need help setting up a trigger:
- The signal is a reset signal.
- Has a period of ten seconds.
- There are two reset pulses - let's say one occurs at t=0 and the second at t=920ms.
I would like to trigger off of the second one and record waveforms immediately.
I tried using delayed trigger but it can "lock" on the second reset pulse one and that doesn't give me the result I need.
I've tried the Timeout Trigger but haven't gotten it to do what I need.
What I think would work - but I don't have - is a holdoff with a count i.e. hold off for 1000ms (to get past the 920ms second pulse) and then trigger on the second rising edge.
Thank you in advance!
