But i really also only envisage doing basic stuff,
That's because you don't own one yet.
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
...and (b) That doesn't mean a more expensive one wouldn't be
much better for a beginner. It's not all about tick boxes on spec sheets, the UI layout can make basic information easier/faster to find and different models can show more information, more clearly, on screen.
eg. Do you want your measurements shown as nondescript numbers at the bottom of the screen or overlaid on the traces, like this?
![first time buyers oscilloscope analysis paralysis help!!!!!](https://www.eevblog.com/forum/index.php?action=dlattach;topic=209409.0;attach=831423;image)
Scopes that do that are more expensive but they can certainly help beginners to use basic functions.
Another example: The Rigol DS1054Z has a row of buttons down the left side for turning on measurements. Push a button, the measurement appears. The Siglents make you go through a bunch of popup windows and require a lot of twisting of the multi function knob to do the same thing.
The Keysight 1000X series is the king of the "stuff that isn't on spec sheets" in the sub-$1000 bracket. It's Dave's favorite daily-use 'scope and easily worth the $150 price difference over the Siglent if you have the budget.
