Author Topic: First picture on EEVblog of the new R&S MXO4 series oscilloscope :)  (Read 63001 times)
Online EEVblog
Re: First picture on EEVblog of the new R&S MXO4 series oscilloscope :)
« Reply #75 on: November 17, 2022, 07:41:18 am »
I've been busy with other videos and scopes, and there was this  :-DD
It's being swapped tomorrow.
https://odysee.com/@eevblog:7/MXO4-Screw-Loose:2
Ah come on, really ? Would have made the "take it apaaaat" one screw faster.
I was actually on a live stream with them going over some of the advanced features when I discovered it. I promised I wouldn't take it apart so they could investigate.
The following users thanked this post: Kean, tooki, pdenisowski, luudee
Offline maxwell3e10
« Reply #76 on: January 11, 2023, 05:20:19 pm »
Is there any update on MXO4? A noise spectrum and characterization of waveform update rate under different conditions would be nice!
Online EEVblog
« Reply #77 on: January 15, 2023, 11:52:22 am »
Plan is to work on it this week. I just got back from a few weeks walkabout.
But I also have other videos I want to get finished, mailbag shelf is full, all the usual excuses...
The following users thanked this post: pdenisowski, VanBudd, luudee, Detlev
Online EEVblog
« Reply #78 on: February 07, 2023, 02:49:24 am »
Finishing shooting the MXO4 unboxing video and tried to test the 4.5Mwfms/sec update, and, well, I don't see it  :-//
The following users thanked this post: egonotto, Martin72, luudee
Online EEVblog
« Reply #79 on: February 07, 2023, 06:15:13 am »
I had the measurements turned on. They said they are going to improve this in future firmware. So much for the ASIC.
Offline goaty
« Reply #80 on: February 08, 2023, 08:23:36 am »
Settings are the same or comparable ? Like trigger level ?
Update rate on the RTB2k also varies a lot and does rarely reach 50k/s.
Online 2N3055
  • Country: hr
« Reply #81 on: February 08, 2023, 11:57:37 am »
That is analytic scope. It is not used that way...
And 4.5 Mtriggers in segmented mode is very good and very useful.
Set scope to long capture and set search for pulse width less than normal clock width. You will have 100% POI.
Or use pulse width trigger, with segmented mode, and assemble statistics of how glitch happens... Also 100% POI..
The following users thanked this post: rf-loop, nctnico, pdenisowski, luudee
Offline goaty
« Reply #82 on: February 08, 2023, 01:08:49 pm »
I wonder why there is this huge "blind time" of more then a millisecond.
That must be some parameters.
Of course one can use fast segmentation mode, but why it needs so much time between triggers ?
The following users thanked this post: luudee
Offline armandine2
« Reply #83 on: February 08, 2023, 02:03:18 pm »
analytic scope versus a display scope?
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
The following users thanked this post: tooki, luudee
Offline bozidarms
  • Country: at
« Reply #84 on: February 08, 2023, 02:13:30 pm »
"Analytic scope" without at least Trends, Tracks and Histograms???
I don't really believe that...
Online 2N3055
  • Country: hr
« Reply #85 on: February 08, 2023, 02:40:15 pm »
Are you serious ?
Honestly I didn't even check so far...  I EXPECTED it to have at least that...
1000€ scopes have that nowadays...
Thank you for this nugget of information...  :-+
That is absolutely epic fail...
What is the price for then... ?
Offline bozidarms
  • Country: at
« Reply #86 on: February 08, 2023, 02:56:20 pm »
Not even simply Histicons ?!?
Prices from Batronix:
R&S® MXO44-2410       4x 1 GHz                                 € 22.848,- inkl. 19% MwSt.
R&S® MXO4-B1 MSO Option                                          € 3.332,-
R&S® MXO4-B6 Funktionsgenerator                               € 1.666,-
R&S® MXO4-B108 Speichererweiterung 800 Mpts            € 3.094,-
R&S® MXO4-K510 I2C, SPI, RS232, UART Dekoder          € 2.856,-
R&S® MXO4-K520 CAN, CAN-FD, CAN-XL Dekoder           € 2.856,-
R&S® MXO4-K36 Bode Plot                                            € 2.380,-
        € 39.032,-  :-DD
« Last Edit: February 08, 2023, 08:31:22 pm by bozidarms »
The following users thanked this post: EEVblog, 2N3055, luudee
Online EEVblog
« Reply #87 on: February 08, 2023, 10:03:05 pm »
No, it has nothing to do with segmented mode at all.
It is literally an architecture bug/limitation where if you turn on the horizontal measurements (like frequency) the update rate drops from 1M/wfs/s to 1K/wfs/s.
Offline nctnico
« Reply #88 on: February 08, 2023, 10:17:05 pm »
Seems reasonable to me as the data needs to be processed for the measurement. Ofcourse there is a choice between using only the Nth acquisition to base calculations on OR doing calculations on all acquisitions. In the first option there is a disconnect between what is shown on screen and what is being calculated.
Online EEVblog
« Reply #89 on: February 08, 2023, 10:19:07 pm »
Online EEVblog
« Reply #90 on: February 08, 2023, 10:20:49 pm »
Not when you realise that the veritcal measurements and cursors have absolutely no impact at all on the waveform speed. It's only very specific horizontal measurements like Frequency which drops the update rate three orders of magnitude.
Offline nctnico
« Reply #91 on: February 08, 2023, 11:03:29 pm »
If you use an R&S scope for a while, you'll see that using the 'Nsingle' setting for doing a segmented recording is a very efficient way to setup a segmented recording sequence. But I agree it isn't very standard and takes some getting used to. I just used it myself a couple of days ago (on the RTM3004).
Offline Fungus
« Reply #92 on: February 09, 2023, 04:24:33 am »
If only there were things called manuals where you could go and type the word "single" and have the answer in a few seconds:
https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/pdm/cl_manuals/user_manual/1335_5337_01/MXO4_UserManual_en_03.pdf
( :box: )
« Last Edit: February 09, 2023, 05:02:20 am by Fungus »
The following users thanked this post: goaty, luudee
« Reply #93 on: February 09, 2023, 08:08:09 am »
Marco Reps is measuring the noise of some ADR1000 with a MXO4:
https://youtu.be/mmsBT3Fuggk?t=3030
He uploaded the video two days ago.
The following users thanked this post: egonotto, pdenisowski
Online EEVblog
« Reply #94 on: February 09, 2023, 08:16:02 am »
Except when the manual is wrong. You have to go into the Segmented menu to find the option to change it.
The following users thanked this post: egonotto, edavid
Online EEVblog
« Reply #95 on: February 09, 2023, 08:19:38 am »
Cool. The Rigol is (slightly) lower noise than the MXO4 though. No surprise given the MXO4 has a 1.5GHz front end. Even if you bandwidth limit, the inherent design noise is higher.
Online EEVblog
« Reply #96 on: February 09, 2023, 08:20:37 am »
Agreed. Segmented mode on most scopes is rather fiddly and annoying in comparison.
Offline bozidarms
  • Country: at
« Reply #97 on: February 09, 2023, 11:14:12 am »
Noise values ​​for one "Industry-leading system architecture: 18-bit vertical resolution/12-bit ADC" are not so exceptional low as R&S would like them to be.
For MXO4 is stated - RMS noise floor ( HD mode ??? active for bandwidth ≤ 500 MHz)
sensitivity:
HDO4: analog bandwidth   1 GHz               LeCroy HDO  1 GHz
0.5 mV/    98 µV
1 mV/       104 µV                                                         145 μVrms
2 mV/       116 µV                                                         145 μVrms
5 mV/       152 µV                                                         150 μVrms
10 mV/      238 µV                                                        155 μVrms
20 mV/      436 µV                                                        185 μVrms
50 mV/      1.01 mV                                                      275 μVrms
100 mV/    2.47 mV                                                      500 μVrms
200 mV/    4.43 mV                                                      1.75 mVrms
500 mV/    10.13 mV                                                    2.75 mVrms
1 V/div      19.96 mV                                                    4.90 mVrms
For example, every LeCroy HD Oscilloscope has in sensitivity over 2mV  significantly better values, partly 4x better!
That is not bashing, only pure facts.
BUT, real bashing can one find on R&S official pages:
https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_common_library/dl_brochures_and_datasheets/pdf_1/Comp_sheet_-_MXO4_vs_Lecroy_WaveSurfer_4000HD.pdf
https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_common_library/dl_brochures_and_datasheets/pdf_1/Comp_sheet_-_MXO4_vs_Tektronix_4_Series_MSO_v1.00.pdf
https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_common_library/dl_brochures_and_datasheets/pdf_1/Comp_sheet_-_MXO4_vs_Keysight_4000_X_v1.00.pdf
If you read something like that, you will be speechless - it's amazing that a company with such a reputation uses such lousy and dirty tricks. - just sad.
« Last Edit: February 09, 2023, 11:42:02 am by bozidarms »
The following users thanked this post: egonotto, luudee
Online EEVblog
« Reply #98 on: February 09, 2023, 11:28:04 am »
Every manufacturer does those comparisons. Lie by omission is the marketing modus operandi.
Offline Fungus
« Reply #99 on: February 09, 2023, 11:33:28 am »
They must have moved it around.
Still, the clue is there...
