Author Topic: Rigol's New DHO800 Oscilloscope unbox & teardown  (Read 339285 times)
Offline Fungus
Re: Rigol's New DHO800 Oscilloscope unbox & teardown
« Reply #2025 on: June 16, 2024, 05:20:02 pm »
If you download the Analog Discovery software you can use it for free on your PC sound card.
I haven't tried it but I'm fairly sure it will do Bode plots up to whatever frequency your sound card supports.
(eg. 192kHz sample rate)
Offline Fungus
« Reply #2026 on: June 18, 2024, 04:25:53 am »
I had both DHO800 and SDS800X HD
While we're here, how do the supplied probes compare?
Offline norbert.kiszka
« Reply #2027 on: August 01, 2024, 04:05:01 pm »
I have had a Lite-On PSU, as it was shipped with DHO924S. Not very best PSU, but for some reasons I decided to do Riso (insulation tester) measurements between PE and output ground. Normal ohm meter showed 1 MΩ. 500 V test gave same result. 1 kV ended with fail - 1 MΩ become 30 kΩ.
If something is powered from grid, at least in Europe, I expect this to handle 2 kV surge without any problem. Anyway, there are some photos from teardown and small reverse engineering of PE-GND path.
Both capacitors are 100 nF, but second one became more like a resistor with value depending on a moon phase.
The following users thanked this post: AndyBig, zelectronicauy
Offline Yuriy V.
  • Country: ru
    • trengtor custom
« Reply #2028 on: August 19, 2024, 08:43:37 am »
Hi, guys!
Could you read my topic & reply to my question about 802/812?
« Last Edit: August 19, 2024, 01:33:29 pm by Yuriy V. »
Offline Fungus
« Reply #2029 on: August 19, 2024, 03:26:16 pm »
Hi, guys!
Very few people but 2 channel models. It's possible nobody here has one.
Offline carl0s
« Reply #2030 on: August 21, 2024, 10:02:26 pm »
Less than £299 including delivery and VAT from Banggood right now (DHO804).
I wanted a portable scope.. really wanted to buy another Siglent but no HDMI and no powerbank option. So a DHO804 it is!
Carl
The following users thanked this post: Fungus
Offline TimFox
« Reply #2031 on: August 21, 2024, 10:31:17 pm »
Hi, guys!
It’s impossible that nobody here owns a two-channel DSO.
The following users thanked this post: Yuriy V.
Offline Elextro
« Reply #2032 on: August 22, 2024, 10:30:46 am »
Hello, I have already answered you in the thread you asked about. My conclusion is that activating the trigger does not influence the maximum sampling frequency, only activating the two channels divides that factor in half. Greetings
Offline Fungus
« Reply #2033 on: August 22, 2024, 01:19:38 pm »
This is very likely, but I'm not going to garantee it because I don't own one.
« Reply #2034 on: August 23, 2024, 01:08:31 am »
Every scope can be modified (another PSU) or powered from a battery->AC inverter.
Offline Fungus
« Reply #2035 on: August 23, 2024, 02:44:20 am »
Yeah, but the Rigol works off a pocket-sized phone charger.
« Reply #2036 on: August 23, 2024, 11:20:18 pm »
You think that other scopes can't be modified to do the same thing?
Offline Fungus
« Reply #2037 on: Yesterday at 04:55:58 am »
Sure, but you don't have to modify the Rigol.
Offline tautech
« Reply #2038 on: Yesterday at 05:25:36 am »
Unless you require a Line trigger.
Offline ebastler
« Reply #2039 on: Yesterday at 10:28:37 am »
Umm -- if you have line voltage around to trigger on, you might as well use it to power the scope?
