I've been reading through this thread, and wow ... still can't believe how almost ANY discussion on the merits of various scopes (or any TE) always seems to degenerate into pointless arguments and "fanboy" accusations ...
My advice, work out what you actually need/want which will probably be at least to some extent different from anyone else's view, do some research, pick one one that looks good and go with it.
Don't expect to make the best decision out of the gate, but you can make a good one. This won't be your last scope. Once you've had one for a while your view on what is good/bad may change.
A few things to consider:
NO scope will be ideal to you. I've been using TE for close to 50 years. I've used dozens of different scopes, have personally had more than a dozen different ones living in my own lab at various points, currently have about 1/2 dozen ponies in the stable, and I can tell you NONE of them are/were "perfect".
The simple reason being that like any product (especially a complex one), they are a compromise. A "feature" that you just love will drive the next guy nuts. TE like anything else can't be all things to all people.
re: AD2
I don't have one, but it looks to be a great little jack-of-all-trades tool that is as Dave says, focused on education.
Would I have it as my first scope? -- probably not.
Would I like one to play with? -- absolutely.
It could be a great second scope, but as my primary bench instrument ... call me old fashioned, but I like a physical scope with real knobs and switches and a separate display on my bench.
I have a USB scope that lives in my laptop bag for times when I'm off-site and don't want to drag along a bench scope. It's great for what it does, but I almost never use it on the bench.
A "virtual" scope needs a mouse, which means you need a place to put a mouse close to your DUT (not always as easy at you would think). It also needs screen real-estate, and more importantly needs "focus" on your screen to make adjustments. If it's the only thing you are using on the computer that's ok, but I am usually looking through data sheets, or at source code (what the ell am I doing to make it do THAT!), hunting some spec. down on the web or whatever ... the point is, having to mouse around, shift focus to the scope, then drag controls - which you have to look at as there's no tactile feedback, is no comparison to just plonking your pinky on a knob and adjusting it while focusing your attention on the display and probe position.
For a first scope, I strongly recommend a "real" one.
Re: DS1054Z
If you don't like it, you don't like it and shouldn't get it. I'm not trying to convince you otherwise, but do consider this before sending the next contender back.
If you really did "returned it the same day", they you probably didn't give it a fair evaluation.
I've had a 1054Z for some time now. I picked it because I wanted 4 channels and deep memory, and since I'm (mostly) retired and don't anticipate generating a lot of revenue from it, yeah.. because it was the cheapest thing available that would do what I wanted and seemed decent.
My first reactions were:
1) Four channels and such deep memory is REALLY nice!
2) I didn't like the combined vertical controls - but given that it was 4 channels in a small size, probably necessary.
3) wow ... is this thing slow!
But I have to say that after using it a bit, I've gotten quite comfortable with it and mostly don't notice the negatives anymore. That's not to say I wouldn't like it to have separate controls or have a faster responding UI, but I wouldn't say they slow me down or cause me anything more than very mild annoyance. It's not actually as slow as it seemed at first, it just stood out as my other scopes have no noticeable UI lag. It's pretty much my go-to scope these days (I *like* deep memory).
I have no doubt that a Tek, Keysight, Lecroy, Siglent, GW etc... would all have things that stand out as negatives to you at first that would ultimately prove to be of less consequence than you think, don't discount any one of them because of first impressions. First impressions are often misleading.
Dave
