Can this firmware be loaded somewhere?
Yes, you can load it on your DS2000/DS2000A. Hi Hi
Version: 00.03.03.02.06 (00.03.03 SP2) Date: 2015-06-17
Go to ->
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-001a/t/page/fm/0 This will get it for you in Rigol's style!.
Select -> 'DS2000Update.zip' to download it.
This is what it improves on:
1. Added the persistence of XY wave.
2. Added the French language menu.
3. Supporting the license file installed by U DISK.
4. Supporting the decoder of multi-modules license file.
5. The screen ASC format screen data are not corresponding with the real values.
6. The position of the Cursor is wrong in the saved snap pictures.
7. Improve the stability the LAN interface communication.
8. Fixed the wave stop refreshing in slow scan mode for MSO serials.
9. Memory LA wave data can’t be saved as CSV format.
10. The parallel decoder result can’t align with the Clock position.
11. The outputs of two Source channels are not equal with each other.
12. The Auto operation can’t execute the auto AC settings correctly.
13. Update the system of SCPI commands.
14. Modified the result type of“:wav:yor..”.
15. Fixed the data fetching of the decoder.
Edited FW version notes. I think we can thank 'Teneyes' for reporting many of these issues to Rigol. Anyway,
thank you Rigol. . .
