Reporting A BUG
on FFT the DSO must maintain the Center frequency selected at the center of the display as you change through span scales
An Update, and very quick, I'm impressed
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Hello Teneyes (edit)
Thanks for sharing the information. I understand what you are saying - that you would like the FFT function to work more like a Spectrum Analyzer where the span adjusts from the center.
All of our scopes operate like the DS2000 because the high end of the span is really set by the time per division of the underlying signal. That timing effects your sample rate on the display and consequently the max frequency. So, as a design decision we made the span move from the left side to keep the accurate parts of the signal on the display as much as possible.
I would actually prefer that the FFT moves from the center like you suggest, but all our scopes currently move from the left. So, for best operation you may want to move your target signal toward the left side before zooming in or set your span first and then adjust the center.
We will submit this as an enhancement request since we think it is a good idea, but as all of our scopes currently operate in this mode I wouldn't expect it to be something that is changed quickly. We will probably need to put some wider organizational thought into it.
Thanks for the feedback!
Chris Armstrong, General Manager , Rigol NA Technologies
Hello Chris
Thank you for the quick response.
Yes, I realize the timebase/sample rate sets the max frequency for the frequency span in FFT mode.
I suggest Rigol keep the setup as is.
But I suggest Rigol add a check to see if the Operator-set Center Frequency is within the span of the 4 choices (determined by time base) then I suggest the program does Not go to the pre=assigned Center frequency but keep the operator selected Center Frequency.
Obviously, entering the FFT mode there is no Center Frequency so setting 0 Hz on left is correct.
Now if the time base is Not changed,
then the changing of the Frequency/div does not change the 4 choices(of span) and the Center frequency is still available, so I suggest keep the Center Frequency at center of the Display.
For that matter even if the time base is changed, if one of the new 4 choices(of span) overlaps the existing selection then keep the same Center Frequency .
Thanks Again
Great process flow summary Teneyes! (edit)
I will pass it along.
thanks for the help making our products better!
Chris
