Good news everyone. I received my DS-2072 from TEquipment today
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
The revisions as received were:
Serial: DS2A151200xxx (under 500)
Soft Ver.: 00.00.01.00.05
Hard Ver.: 1.0.1.0.0
SPU: 03.01.02
WPU: 00.06.00
CCU: 12.29.00
MPU: 00.05
After doing some bandwidth and risetime tests, I tried to apply the keys to unlock bandwidth and options. I got all the options turned on except for 200Mhz b/w. The model # stayed 2072
![Angry >:(](https://www.eevblog.com/forum/Smileys/default/angry.gif)
. I tried several times, first just the DSA9 key, then the DSAR followed by DSA9 keys but it still stayed a 2072
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
. I tried updating the firmware to 01.01.00.02 then applied the DSAR & DSA9 keys. Success! This time everything including the 200 MHz b/w were unlocked
![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
. Not sure why it wouldn't work prior to the FW update
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Using a Rohde & Schwarz SMS generator into a 50 ohm passthru, I did 2 simple plots of freq. vs mV thru 500 MHz before and after applying the keys. The results tracked close to Wim13's results with a similar setup (post #1215 Pg. 82).
To check risetime, I used a Tek PG 502 pulse generator with a spec'd risetime of <= 1 nS feeding the DS2072 thru a Tek 50 ohm feedthru terminator. Prior to applying the keys, I got a risetime of 2.5 nS. After applying the keys, it dropped to 1.3 nS, also in line with other folks results IIRC.
Again, a huge thank you to Marmad, cybernet, teneyes, Wim13, and all the others that have contributed so much to the collective knowledge regarding these scopes
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Marc -
