* NEW FIRMWARE FOR DS2000: FW v.01.00.00.03 *![](https://www.eevblog.com/forum/testgear/first-impressions-and-review-of-the-rigol-ds2072-ds2000-series-dso/?action=dlattach;attach=43911)
Over the last couple of months we've been giving Rigol the occasional hard time for being late with the promised firmware update. Well, it's now here - and although, after having tested it for an hour or so, I haven't seen any new features - Rigol appears to have gone down our bug list (from
Page 1 of this thread) and killed (most of) them one by one. All credit to Rigol - they have clearly responded to the complaints we've posted here - and though I haven't tested enough to be absolutely sure, I can only find
one two remaining bugs from the list that they didn't get yet (
Edit: As Dave pointed out - there is also still the update 'bug'; which makes it slightly complicated to update the FW [the GUI menu option doesn't work] - but that wasn't in the original list since it was assumed to be gone) .
Here is the list again from FW v.00.01.00.05 - and what appears to be fixed in FW v.01.00.00.03:
1) The scope appears to first clear the display then restart the sweep whenever moving the waveform vertically, changing the vertical or horizontal scale, moving trigger position, turning on/off channels, etc.
Fixed!! Yay, they are no longer clearing the waveform before moving it horizontally or vertically. It feels much more responsive.2) The way the scope handles intensity grading in delayed sweep mode needs some work - it doesn't appear to be the same as if you just stop the sweep and zoom in via the horizontal scale.
Fixed3) If you use the FINE horizontal scale adjust at scales >=20ms (Press -> [Horizontal] Menu -> ScaleAdjust -> Fine), the max/min horizontal trigger position becomes locked to the next lower major division*10/14 - instead of staying 10x/14x of whatever the actual setting is.
Fixed4) When you turn on tracking cursors (if all cursors off), the measurement window doesn't appear.
Fixed5) X-Y channels are reversed.
Fixed6) Self-calibration will automatically expire any trial options currently running.
Not fixed.7) AUTO routine sometimes fails to latch onto signals.
Unknown - the AUTO routine on every DSO that I've used fails sometimes. In any case, it was never a problem for me, so I'll let someone else test it.8 ) The 'repeat' (looping) playback of frames recorded in Record Open mode doesn't seem to work correctly (hardly ever).
Fixed9) There is a major bug involving the transfer of sample memory between the DSO and the PC - which you normally do using VISA and SCPI commands.
Fixed10) There is a bug involving the reading of WFM files into DSO memory.
Fixed11) Anti-Aliasing does not return to ON when the DSO is powered-up, even if the Menu setting shows it as "ON".
Fixed12) A bug confined to the menu selection of Channel 1 = ON and Trigger = External keeps the sample rate stuck at 1G SA/s (instead of raising to 2G Sa/s - as it should be).
Fixed13) When using both channels and attempting to read 7MB (or 28MB) sample depths out of the scope, the DSO transfers the wrong number of bytes (something 'random' between 6.9 - 7MB (or 27 - 28MB)).
Not fixed.Good job, Rigol! Now, can you please add Save/Load for Recorded Frames and some other
new features?
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
