What programming language and dev. environment are you using for your software development? What is the communications protocol to talk with the DS2000? Very exciting!
I'm using Visual Studio and the National Instruments VISA DLLs - talking to the device with SCPI.
Ok, it was rather late last night when I posted the first DS2000 screen-video - getting frustrated because of YouTube's compression - and I forgot to create a little FlashPlayer on the page I linked to. Now I have and it's much better. So here is the second test of creating an H264 encoded video from the recorded frames (i.e. segments of memory) on the Rigol DS2072:
Logarithmic sweep: 10Hz - 40kHz with sync pulse, while displaying one reference square wave of 1kHz and one of 10kHz.
1700 frames @ 34". I'm playing back at 50 fps, so you'll notice the clock counting seconds faster than normal. Also my software hit a bug near the end, so the last ~100 frames were captured later on (you can see the clock jump)
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
It's a 15MB movie, so it can take a few moments (depending on your connection speed) to start playing:
http://turbidmedia.com/ds2000.htmlAlso, as of today, my reanimated trial options are still working fine - third day running
Edit: I tried to attach a smaller version for download here, but it appears the blog doesn't allow video file types
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Perhaps, it's time to change that? Anyway, here is a download link for a smaller version: 250 frames @30fps real-time:
http://turbidmedia.com/ds2072.mov
