Yes!
There was a noticeable lag (maybe a second or so), but as I was moving between frames in analyze mode the decoding was eventually getting updated. :-)
Great! Good to hear it - and thanks for posting the info (plus welcome to the forum
I can confirm that it also works with the CAN analyzer (DS2000A).
Later added: Updating from 00.03.01.00.03 is save: you will not loose any options etc.One short hint to the update procedure:a)
Check! It took me 4 or 5 attempts to get the scope updated. Even as it looked like the scope was updating (Ch1 blinking for some time, then after a while all leds lit), the scope was not updated (check with 7-6-7-utility as mentioned before). I changed nothing: the USB stick was one I was using all the time with this scope without any problem before. I just tried it again and again.
So, if you have this problem too: just keep trying and don't forget to check the system info after updating.
b)
FRAM: Even as I updated only from 00.03.01.00.03 to 00.03.01.00.04, I needed to run the FRAM deleting procedure Marmad is mentioning in post at the beginning. I did not clear FRAM first, as his post also says "only needed for major updates". As my scope had some strange behaviour in some menus (I first thought the new firmware was bullsh*), I cleared it during booting. After clearing the FRAM, everything is fine now. @Marmad: better change this to a "always to-do".
