Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1131866 times)
0 Members and 27 Guests are viewing this topic.
Offline Mark_O
Re: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol
« Reply #2300 on: March 08, 2014, 05:23:46 am »
UI of triggering is strange, for example I want to see RS232 data as ASCI chars, I see interesting place to me, and want to trigger on specific letter 'D' for example. For that purpose I need to find somewhere ASCI codes table and find the number of that letter.  |O
Yes, that's definitely a PITA.
Just because triggering UI works with numbers only, no letters, no HEX. :-//
I've found picture with another example, I2C decoding shows hex values, triggering works with dec values only.
Thanks for the screenshot on that.  At first I was confused, but then I realized that while Rigol provides several different output formats, only one input format is available (decimal numerics).  Thanks!
Offline rowifi
« Reply #2301 on: March 13, 2014, 01:36:35 pm »
My DS2202A has locked up again..
This time I was messing with the measurement buttons and I believe it was the 'STATS' button that I pressed. The scope then goes unresponsive.
Basically I had ALL those yellow measurement readings on the screen and I was looking for a button to kill them. I could turn them all off , but haven't yet seen how to change them individually.
Whatever - the scope should not lock up, and worst - a power cycle does not fix it...
It sits there .. dead showing the Rigol logo.  Scope is virtually new - unadulterated.
In all it seems a nice scope  - but I'm going to get bored if I keep having to reflash the firmware every so often!
**UPDATE**  Power cycle with 6th Grey button being repeated pressed has unlocked it...  back in business.
« Last Edit: March 13, 2014, 01:46:40 pm by rowifi »
Offline bronson
« Reply #2302 on: March 13, 2014, 04:41:37 pm »
Twice??  That sounds like a broken scope.  I'd file a support request.
Offline rowifi
« Reply #2303 on: March 14, 2014, 11:57:53 am »
Yes - done that, but since it happened both times since after I did a firmware upgrade, and only this timerecovered the scope using the '6th grey button' ( set defaults), I'm going to assume it was something to do with that ( for now)... ...
oh oh.... Just been trying it.. pressing the Statistic button has locked it up again.
Mode: Just channel 1 display ON.  No Input signal. Display All ON.  From a power up having only been messing with the measure functions.
I don't expect a power cycle to clear it alone....
Nope, just 3 beeps and then stuck.
Booting while pressing  grey  button no 6 fixes it.
I can't seem to replicate it... but so far each lockup has been related to the Display All , All Measure and Statistic buttons.
Edit:
Now I can repeat it ..
Power up:
Press 6th left hand grey button once  ( to activate menu ) press again to select 'width'.
Press 7th left hand grey button to activate 'duty'
Press Measure
Check vertical channel 1 operates by adjusting knob
Press 'Statistic'
Check vertical channel 1 now doesn't operate. Scope is locked up and needs a reset to default to operate again.
« Last Edit: March 14, 2014, 03:23:45 pm by rowifi »
Offline hibone
« Reply #2304 on: March 14, 2014, 05:51:38 pm »
I've bought the Rigol 2072A-S. I was looking for the original firmware but the one in the first page is not available anymore.
Is it possible to update the page with a new link?
Thanks you...
Offline Sparky
« Reply #2305 on: March 15, 2014, 12:01:37 am »
Some guy posted that there is a version 00.03 firmware from Rigol.  He did not share with us though :(
Anyone else hear about a new 00.03 firmware for DS2000/DS2000A series?
Offline ve7xen
    • VE7XEN Blog
« Reply #2306 on: March 15, 2014, 12:03:39 am »
Someone sent it to me (might be the same guy) by e-mail. I put it up on my website, but I was just assuming it was actually the existing version from February, so the filename is wrong if it is in fact a new version. I won't be able to try it for a few days, but the file is:
http://www.gotroot.ca/rigol/DS2000-02_01_00_03.7z
If anyone else wants to give it a stab. Let me know if I should rename it...
« Last Edit: March 15, 2014, 12:05:10 am by ve7xen »
73 de VE7XEN
He/Him
Offline Sparky
« Reply #2307 on: March 15, 2014, 12:12:28 am »
Someone sent it to me (might be the same guy) by e-mail. I put it up on my website .... the file is:
http://www.gotroot.ca/rigol/DS2000-03_00_00_00.7z
Thanks!  The file is much larger than previous .GEL files.
Edit: Updated link
« Last Edit: March 15, 2014, 03:50:20 pm by Sparky »
Offline NYG
« Reply #2308 on: March 15, 2014, 03:08:50 am »
Thanks!  The compressed filename is indeed wrong, but the .GEL binary file has ASCII numbers 00.03.00.00.00 at the beginning.
Well, the glass of whiskey in my hand kept telling me to load the new firmware, so I did.
BTW is there any difference upgrading by booting and hitting help a couple of times with the image on the USB drive, or just booting normally, sticking the drive in and following the upgrade prompts? I just followed the on screen prompts when it was fully booted this time around.
My DS2072A reads:
Model: DS2302A
Software Version: 00.03.00
Hardware Version: 2.0
All options still showing installed as "Official Version"
Don't know what's changed or been fixed, but that's what I can see for now.
I may try downgrading just to see what happens.
Offline ve7xen
    • VE7XEN Blog
« Reply #2309 on: March 15, 2014, 10:25:02 am »
I renamed the file. New link:
If anyone has the actual 00.02.01.00.03 files I'd appreciate a copy to put up. The rapidshare links upthread are all broken for me.
73 de VE7XEN
He/Him
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
« Reply #2310 on: March 15, 2014, 02:17:50 pm »
I've fixed the FW links in the second post (moved all the files from rapidshare to my own server) and added the latest v.03 to the list.  I haven't heard anything about this latest version, but I'm currently travelling and away from the DSO, so no chance to experiment with it for awhile.
Somebody else might experiment and see if Rigol has dealt with any of the bugs listed in the above-linked post.
« Last Edit: March 15, 2014, 02:20:48 pm by marmad »
Offline Teneyes
« Reply #2311 on: March 15, 2014, 04:24:52 pm »
FW 00.03.00 ??
Tested Math Log() function,  working but the DSO locks up!
   See log of a sawtooth with a bit of Negative values;    Note log(-negative) = 0
   DSO display and controls Lock up when you try to edit expression 'Off'
   but USB still reports the display with a SCPI command
It is looking like this is a Beta Version
NO fix of Bugs 17,18..
Back to FW#00.02.01.00.03
« Last Edit: March 16, 2014, 04:47:43 pm by Teneyes »
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
Offline Hydrawerk
« Reply #2312 on: March 22, 2014, 12:06:42 am »
Sometimes the intensity stays tha same even if you try to adjust it. Probably someone has noticed it here. This issue appears at certain memory length settings, I think.
Offline Teneyes
« Reply #2313 on: March 22, 2014, 05:34:51 am »
Hi Hydrawerk
    I did some testing and noted that in the Video there was recording frames with the Persistence not set to Min.
when in Min persistence , and Frames are recorded and the Rigol will Play back the frames at a Fix normal visible intensity (about same as Infinite persistence brightness)
But when the persistence is not set to Min. the Frames are recorded at that intensity setting and you cannot adjust the playback intensity.
  when the intensity is set low  during record, you can Barely  see the waveform
and
  when the intensity is set High during record, you can Clearly see the waveform
What does persistence mean if recording frames? ( could be segmented frames)
Shown below are 4 Displays:  7% intensity, 50% intensity, 100% intensity,  0% intensity but Min. Persistence
I hope that helps show what happens
« Last Edit: March 22, 2014, 05:47:56 am by Teneyes »
Offline Pehtoori
« Reply #2314 on: March 23, 2014, 09:24:17 pm »
Close the menu and you can adjust intensity. Should read the manual carefully! :-DD
Offline Hydrawerk
« Reply #2315 on: March 23, 2014, 09:37:12 pm »
OK, I should have read the manual...
Offline tigerwillow1
« Reply #2316 on: April 03, 2014, 09:21:33 pm »
My Wave Intensity always goes to 50% no matter what I attempt to set it to.  Is this the same issue as in the previous few posts?  Brightness adjusts the grid intensity and works ok.
Offline JDubU
« Reply #2317 on: April 04, 2014, 12:14:01 am »
Pushing down on the intensity adjustment knob sets the intensity to 50% (it's a shortcut).
Don't push it down after adjusting the intensity.  Just stop turning the knob and the intensity will lock to your setting after a second or so.
« Reply #2318 on: April 04, 2014, 01:31:40 am »
OK, I didn't know that.  I did read the "waveform intensity" part of the book.  So now, the intensity setting stays where I set it, but it doesn't change the brightness of the waveform.  Am I interpreting what the "waveform" is?  I think it's the yellow and blue channel 1/channel 2 traces.  I upgraded to 00.02.01.00.03 this morning.  I "think" the intensity used to work ok, but my memory is not to be trusted, either.
Offline JDubU
« Reply #2319 on: April 04, 2014, 04:17:44 am »
Yes, the waveform intensity control is the brightness of the traces.
The range of brightness is not very dramatic.  Try looking at the rise/fall transitions of the calibration waveform as you adjust the intensity.  You should see the brightness change in them
Offline Sparky
« Reply #2320 on: April 04, 2014, 06:21:00 am »
May be this already mentioned somewhere, but I just noticed it: MSO version of DS2000A series is coming!
Maybe that's what the big v00.03 firmware update and version number jump is about?!
See http://www.rigol.com/ and select the Chinese localization.
« Last Edit: April 04, 2014, 09:11:51 am by Sparky »
Offline Carrington
« Reply #2321 on: April 04, 2014, 08:59:04 am »
Are there any rumours or confirmations about upcoming DS2000 series with built-in LA?
Will the LA have 8 channels or 16 channels? When is it expected? Details on launch date and model numbers? Pictures?
My speculations:
  - Upcoming DS2000 series with built-in LA? Yes, no doubt!
  - Model numbers: DS2072AD, DS2102AD, DS2202AD and DS2302AD.
  - LA 8 Channels at 1GSPS.
  - Launch in the EU, 6 months after it is launched in China.
https://www.eevblog.com/forum/testgear/rigol-ds2000-series-model-designation/
https://www.eevblog.com/forum/testgear/rigol-ds2000-hardware-version-2-0/msg270640/#msg270640
Very good news.  :-+
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline Sparky
« Reply #2322 on: April 04, 2014, 09:17:08 am »
My speculations:
Very good news.  :-+
Good prediction!  Seems to be 16 channel LA; I'm not sure what the sample rates are though.
« Reply #2323 on: April 04, 2014, 08:41:46 pm »
The range of brightness is not very dramatic.  Try looking at the rise/fall transitions of the calibration waveform as you adjust the intensity.  You should see the brightness change in them.
You are 100% correct.  When looking at the square wave, brightness has a good effect on the rise/fall lines, and does close to zilch for the horizontal lines.  I finally found the button-push 50% brightness setting in the manual section for the multi-function knob.  So if you read and remember the whole manual, the info is there.  If you use it as a single-subject reference, you'll never find how the knob push sets the brightness.  Thanks, from a part-time user who doesn't remember all the details.
Offline Mark_O
« Reply #2324 on: April 05, 2014, 02:23:19 am »
That just went public recently.  I don't think it's been mentioned here yet.  Good catch!   :-+
Yes, there were significant changes to the FW (and substantial increases in size) to incorporate the new LA functionality, AND all the new SCPI commands supporting it.
They obviously focused on those enhancements, and de-prioritized correcting known bugs on the analog side (for now).
« Last Edit: April 05, 2014, 02:26:11 am by Mark_O »
