Loading [MathJax]/extensions/Safe.js
Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1240881 times)
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
Re: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol
« Reply #1750 on: November 21, 2013, 01:44:26 pm »
@Galaxyrise: I just discovered something else: you CAN switch your recorded frames from High Res to Normal mode - just enter Delayed Sweep (Zoom). The DSO will automatically switch to rendering the frames with High Res turned-off. But once High Res is off, exiting Delayed Sweep does not turn it back on again.
« Last Edit: November 21, 2013, 01:49:14 pm by marmad »
Offline Galaxyrise
« Reply #1751 on: November 21, 2013, 04:29:57 pm »
Ha! At this point, I'm inclined to think the inability to switch high res and normal is just a firmware bug.  They even left the menu enabled (unlike memory depth.)
I am but an egg
Offline bingo600
« Reply #1752 on: November 22, 2013, 08:39:31 am »
Guyzz
I'm considering getting a DS2072A (EU / Batronix) , but i want to be 100% sure it's "upgradeable" with the nice tools out there.
1: Had anyone reported back with a positive confirmation , that the A can be "upgraded" like the Non A
2: Does it give the same features as the Non A ?
3: Does anyone know if the 2072A's are what Batronix are shipping now , or should one wait a bit to be sure to get an A'.
/Bingo
  • Country: aq
    • DaysAlive
« Reply #1753 on: November 22, 2013, 10:15:28 am »
As far as I've heard, Rigol has changed the key (or something) on the 'A' version, making it incompatible with the current hacking tools.
Offline bingo600
« Reply #1754 on: November 22, 2013, 10:30:33 pm »
Hmm ....
Too bad , i'll skip on Rigol for now , and look at some of the others.
/Bingo
  • Country: aq
    • DaysAlive
« Reply #1755 on: November 23, 2013, 12:12:16 pm »
I've updated the High Res bandwidth table to reflect all Memory Depth Settings:
Two interesting things to note:
1) The bandwidths are similar down to the 20us/div time base setting - but the effective bits of resolution differs at the 10us/div and 20us/div settings.
2) The bandwidths of the 56M memory depth setting are the same as the 1.4M setting, except at 500us/div, 5ms/div, and 50ms/div - where it instead matches the AUTO/14M setting.
« Last Edit: November 23, 2013, 01:29:19 pm by marmad »
Offline Carrington
« Reply #1756 on: November 23, 2013, 08:48:14 pm »
CAN-DS2000A
CAN trigger and decode for DS2000 and DS2000A.
Source: http://www.tequipment.net/RigolPricelist.html
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
  • Country: aq
    • DaysAlive
« Reply #1757 on: November 23, 2013, 09:00:25 pm »
CAN-DS2000A
Interesting. I wonder if it really works with all older model DS2000s (HW v.1)? If it does, it must require a firmware upgrade.
Offline Carrington
« Reply #1758 on: November 23, 2013, 09:05:32 pm »
I hope so, because mine is 1.0.  :D
Space Weather.
Offline kosh
« Reply #1759 on: November 25, 2013, 04:52:02 pm »
something strange has happened to my scope. A few days ago the trial options on my DS2072 ran out. So I decided it was time for a firmware upgrade and a calibration, which I was hesitant with until now.
So I upgraded from version 00.01.00.00.03 to the latest 00.01.01.00.02 and after that I ran the calibration procedure. I have used the device several times after that and I think I even checked to see if the trial options were still gone, and sure enough they were.
Today I power on my scope and I am being greeted with the boot message showing the trial options with over 2000 minutes left again, and yes all the menus that were greyed out before are now accessible again.
I am not complaining, but wondering, has this happened to anyone else?
  • Country: aq
    • DaysAlive
« Reply #1760 on: November 25, 2013, 04:57:58 pm »
Many times. Before the current keygens, we would just restart the trial options by changing the date/time in combination with a self-cal. Super easy to do.
  • Country: aq
    • DaysAlive
« Reply #1761 on: November 25, 2013, 05:20:19 pm »
I've owned the DS2072 exactly 13 months today (since 25-10-12).
In the first ~8.5 months (pre-keygen hacks), there were 3 firmware upgrades from Rigol (4, if you count from the Western release date).
In the next ~4.5 months (post-keygen hacks), there were 0 firmware upgrades from Rigol.
Of course, this could be totally due to the roll-out of the newer models - but I hope Rigol doesn't consider the latest version "finished" (for the older models). They had promised some 'upgrade' of the External Trigger capabilities, and I still hope they will deliver on this.
« Last Edit: November 25, 2013, 05:30:53 pm by marmad »
Offline cybernet
  • pm deactivated, use the search function ...
« Reply #1762 on: November 25, 2013, 05:53:19 pm »
we will soon be able to do our own ...  >:D
___________________
"all rights reversed :-)"
R0=-0x18;
UNLINK;
RTS;
Offline Carrington
« Reply #1763 on: November 25, 2013, 06:29:48 pm »
Soon!!!!   8)
Space Weather.
Offline Bugware
« Reply #1764 on: November 25, 2013, 08:48:57 pm »
That sounds very mysterious. I'm curious.  :)
(Hack the 2000A Version to use for the non "A" Versions?!)
  • Country: aq
    • DaysAlive
« Reply #1765 on: November 29, 2013, 11:57:28 am »
Following up on some info discovered about the DS2000 in another thread, I thought I'd post the info here in an effort to inform owners who hadn't seen it there.
The DS2000 series appears to have trigger jitter/offset in the Zoomed trace while at lower sample rates (in Delayed Sweep mode). It appears to follow this pattern:
When in Delayed Sweep mode:
Sample rate >= 1GSa/s: no conspicuous jitter or offset
Sample rate <= 500Ms/s: jitter and/or offset equal to a maximum of plus or minus one sample period
So for example, @ 200MSa/s it's equal to ±5n, while @ 10MSa/s it's equal to ±100ns.
I'm not sure yet if this is a firmware issue or not (these tests are from the latest FW version). If someone has a chance to test a lower FW version, please post the results here.
Here is an example of jitter @ 100MSa/s  (i.e. ±10ns) in Delayed Sweep:
Rigol's response to this 'issue' is here.
« Last Edit: December 06, 2013, 05:54:27 pm by marmad »
Offline sync
« Reply #1766 on: November 29, 2013, 02:54:52 pm »
FYI the DS1000Z has that jitter too.
Offline Wim13
« Reply #1767 on: November 29, 2013, 03:03:25 pm »
Has all to do with phase differences..
If you synchro the clock rate off the DSO with signal generator it stands still.
Offline Carrington
« Reply #1768 on: November 29, 2013, 03:53:36 pm »
LOL... The DS2000 and the average of everything that shakes.
Normal:
Average:
This also has to do with phase, in this case phase trigger/signal. Playing with holdoff, can be corrected.
I think that David L. Jones has a video about something similar.
« Last Edit: November 29, 2013, 04:07:33 pm by Carrington »
Space Weather.
  • Country: aq
    • DaysAlive
« Reply #1769 on: November 29, 2013, 03:59:31 pm »
Thanks for the info, sync.
Hey Wim - good to see a post from you  :)
Phase difference between what, exactly? Between the sample rate and the delayed sweep rate?
« Last Edit: November 29, 2013, 04:05:31 pm by marmad »
Offline Carrington
« Reply #1770 on: November 29, 2013, 04:02:17 pm »
Yes, it seems logical.
Space Weather.
Offline tinhead
« Reply #1771 on: November 29, 2013, 04:13:45 pm »
lol, Wim, what's that? of course there will be no phase variation (jitter) when measured signal is referenced to itself. But we not talking about that, but about the jitter added by trigger circuit, signal paths, FPGA design and potential firmware implementation.
Offline Carrington
« Reply #1772 on: November 29, 2013, 04:22:34 pm »
LOL...
« Last Edit: November 29, 2013, 04:35:08 pm by Carrington »
Space Weather.
  • Country: aq
    • DaysAlive
« Reply #1773 on: November 29, 2013, 04:25:34 pm »
Sorry, man, I don't think you're correct. The jitter/offset (which, BTW, the new Siglent has as well as shown by Herman's GIF - so arguments of analog vs digital trigger don't hold water here) has to do specifically with some interaction between the main time base sample rate and the delayed time base. There is no jitter/offset (in this circumstance) outside of using Delayed Sweep.
« Last Edit: November 29, 2013, 04:30:22 pm by marmad »
Offline Carrington
« Reply #1774 on: November 29, 2013, 04:28:38 pm »
Sorry, man, I don't think you're correct. The jitter/offset (which, BTW, the new Siglent has as well as shown by Herman's GIF) has to do specifically with some interaction between the main time base sample rate and the delayed time base.
Then are different and don't go on phase?  :-//
It is true, good point.
Then only, FPGA design and potential firmware implementation?  :-//
« Last Edit: November 29, 2013, 04:37:30 pm by Carrington »
Space Weather.
