Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1123877 times)
Offline leafi
Does anyone else's DS2702 have a low frequency buzzing sound coming from the power supply area? It sounds like my transformer is buzzing. I am not looking forward to RMA'ing the scope I just got today.
Offline bronson
Unfortunately no. Other than the overeager fan, this thing is pretty much silent.
Offline up8051
Re: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol
« Reply #1627 on: August 01, 2013, 10:48:39 am »
Serial: DS2A15270XXXX
Software version: 00.01.01.00.02 (latest I believe?)
Hardware version: 1.0.1.0.0
DS2A1527xxxxx (Week 27, 2013) -> RP3300A
Serial: DS2A1527XXXXX
Hardware version: 2.0
DS2A1520xxxxx (Week 20, 2013) -> RP3300
Hi All,
My DS2072 I got yesterday came with the switchable RP3300 probes.
Serial: DS2A1509XXXXXX ( (Week 9, 2013 ?)
Software version: 00.00.01
Probes ->  RP3300
No information about FPGA version
Is the latest firmware?
Why version numbers are in short form?
Best regards,
up8051
Offline Carrington
« Reply #1628 on: August 01, 2013, 10:57:42 am »
I've noticed that with the series DS2A1527XXXXX RIGOL not only changed the probes.
UberSteve: https://www.eevblog.com/forum/testgear/first-impressions-and-review-of-the-rigol-ds2072-ds2000-series-dso/msg263616/#msg263616
Leonard Tatzig: https://www.eevblog.com/forum/testgear/sniffing-the-rigol%27s-internal-i2c-bus/msg269946/#msg269946
Carrington: https://www.eevblog.com/forum/testgear/first-impressions-and-review-of-the-rigol-ds2072-ds2000-series-dso/msg264041/#msg264041
Hi All,
Probes ->  RP3300
Best regards,
up8051
https://www.eevblog.com/forum/testgear/first-impressions-and-review-of-the-rigol-ds2072-ds2000-series-dso/msg158684/#msg158684
To get the full firmware version info from the DSO, follow these instructions:
Go to the Trigger menu and set Edge trigger.
While keeping the Trigger menu open, you are going to use the 6th and 7th right-side menu buttons as follows:
Press the [Menu7][Menu6][Menu7][Utility] buttons one after another quickly.
Then check additional info under System -> System Info.
Please post the result.
Note: I allowed myself to edit your post to clarify.
Cheers.
« Last Edit: August 01, 2013, 11:00:57 am by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline up8051
« Reply #1629 on: August 01, 2013, 01:45:58 pm »
Full info:
Software version: 00.00.01.00.05
FPGA version:
 SPU 03.01.05
 WPU 00.06.00
 CCU 12.29.00
 MCU 00.05
RP3300 probes
Best regards,
up8051
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
« Reply #1630 on: August 01, 2013, 06:18:50 pm »
Old FW version - there have been 2 releases since the one you have. You can find download links and instructions for upgrading on the first page of this thread.
Offline Carrington
« Reply #1631 on: August 01, 2013, 06:54:25 pm »
Anyone know how many versions of HW exist until today's date?
1.0 -> 1.0.1.0.0 -> 2.0  :-//
Thanks.
Okay I think I have the answer, just two HW version: 1.0.1.0.0 -> 2.0.
And I have the feeling that in the 2.0 Ver. they have improved the PSU and DC/DC parts.
« Last Edit: August 01, 2013, 08:21:12 pm by Carrington »
Space Weather.
Online Electro Fan
Off Topic Question for marmad
« Reply #1632 on: August 01, 2013, 07:04:19 pm »
Just checking to see if you could feed a string such as 01000001 which represents “A” in ASCII (by simply turning on and off voltage at some level (maybe 3.3V or 5V) over periodically uniform time intervals and have the 2072 decode the 1s and 0s string into the letter A?  Thanks!
« Last Edit: August 01, 2013, 07:06:22 pm by Electro Fan »
Offline Carrington
Re: Off Topic Question for marmad
« Reply #1633 on: August 01, 2013, 07:06:24 pm »
Just checking to see if you could feed a string such as 01000001 which represents “A” in ASCII (by simply turning on and off voltage at some level (maybe 3.3V or 5V) over periodically uniform time intervals and have the 2072 decode 1s and 0s into the letter A?  Thanks!
What?
Space Weather.
Online Electro Fan
« Reply #1634 on: August 01, 2013, 07:56:44 pm »
What?
Hi Carrington,
Sorry, that probably wasn't fully clear (and I'm sure it was off topic from the current page in this 100+ page thread, but I generally look at it as this thread as "the Encylopedia of Rigol 2072" thread), and EEV + marmad et al as Guttenberg.
What I was asking about was focused on the capabilities of the Rigol decoder option.
I understand that if you probe, for example, a I2C signal with a 2072 that has the decoder option (SD-DS2) turned on, that you can decode the I2C signal into hex, ascii, decimal, and binary.
So, my question was simply if you could deocode an ascii string that wasn't derived specifically from an I2C signal, but was in fact a legitimate ascii character (such as the letter A).
To test this, one could conceivably generate a signal by driving voltage high and low at intervals that would correspond to a given character and then probe the signal with a 2072 with the SD-DS2 option.  Whether the Decoding Table or Event Table would decode and display such a string is the question.
http://www.tequipment.net/RigolSD-DS2.html
- I think this is the manual for the SD-DS2 and I think it applies to the DS2000 series and the DS4000 series, but I'm not 100% sure.
« Last Edit: August 01, 2013, 08:00:49 pm by Electro Fan »
Offline Carrington
« Reply #1635 on: August 01, 2013, 08:04:55 pm »
Hi Electro Fan!
Okay, now I understand.
But I don't know what result will give it.
Space Weather.
Online PA0PBZ
« Reply #1636 on: August 01, 2013, 08:07:02 pm »
I guess you can decode any signal into ASCII, but you need either to specify the baudrate (like in RS-232) or you need a data and a clock line.
It also has something called parallel decode, I'm still puzzled how that is going to work with just 2 channels...
Online Electro Fan
« Reply #1637 on: August 01, 2013, 08:17:01 pm »
Ok, cool - so that would be two separate ways to set it up?
1) make sure to generate the probed signal at one of the specified baud rates, or
2) provide a separate clock line
- either approach should work fine given that the 2072 has 2 available channels
- just curious to see if anyone wants to confirm this is possible by giving it a try  :-BROKE (This icon is entitled Broken! but it looked like a great one for "please see if you can decode an ASCII string on your 2072, Thx")
Offline carpelux
« Reply #1638 on: August 03, 2013, 12:03:59 pm »
Another DS2072 buy trigged by the great work done by some people here. Big thanks to you all!
Received the scope yesterday. It was manufactured week 27 and came with latest FW (00.01.01.00.02) and RP300A probes but with hw 1.0.1.0.0. I did enter a DSAZ key by the scope keypad, and it worked a treat on first try. Scope is now fully unlocked and no problem what so ever with serial number.
Once again, big thanks to all of You!
Catch the light
Online PA0PBZ
« Reply #1639 on: August 03, 2013, 02:26:07 pm »
Here you go:
Online Electro Fan
« Reply #1640 on: August 04, 2013, 12:07:24 am »
Here you go:
NICE!!
PAOPBZ - any chance you can walk us through the steps you took to do that?
Thanks!  EF
Offline tlu
« Reply #1641 on: August 04, 2013, 10:25:25 am »
I'm also curious as to how you manage to achieve this. Please do tell us your set up as I want to try this out for myself as well.
Online PA0PBZ
« Reply #1642 on: August 04, 2013, 04:58:45 pm »
It is really very easy: Hook one channel up to the output of an RS232 port, press one of the decode buttons and set up the parameters, see attachment 1. Then send you character(s) over the line and enjoy. There is also a cute event table, see attachment 2.
Offline K3KO
« Reply #1643 on: August 05, 2013, 05:34:41 am »
I'm in the process of buying either the 2072 or 2102.  Given the below remarks.  Which model makes the most sense to purchase.
(I really wanted the 200 MHz bandwidth/ 2 ns /1.8ns risetime model but the prices is out of sight.)
I see there was some success in hacking the 2072 so that one can essentially have a 2202.
However,  I was unable to find exactly how this is done among the 100 pages of postings.
Is there a link which gives software (WINDOWS) and instructions a neophyte hacker could follow?
New to digital scopes and right now a bit overwhelmed with the capabilities!
Brian
Online PA0PBZ
« Reply #1644 on: August 05, 2013, 08:32:35 am »
PM sent.
Offline Mr Simpleton
  • Not the sharpest knife in the drawer
« Reply #1645 on: August 05, 2013, 02:10:50 pm »
My 2072 was received today and had the following loaded:
DS2A1520xxxxx with RP3300 switchable 350MHz probes
sw ver 00.01.01.00.02
hw ver 1.0.1.0.0
FPGA
SPU 03.01.05
WPU 00.06.05
CCU 12.29.00
MCU 00.05
Have yet to crack it open to see what's inside!
Offline K3KO
« Reply #1646 on: August 05, 2013, 11:18:03 pm »
Ordered today for TEquipment.  Estimated shipping date 8/23....  Rats.  Guess it's popular.
Trying to sort through the documentation.  It appears that the 300 Meg Ultra Sigma software is needed only to install USB drivers-- if you're not going to query and receive data using it.  RUU2.03 seems like a better route.
If  I understand properly the VISA520runtime.exe routines  install the drivers for you (100 meg!). Strikes me that 100 meg is a lot for just drivers.    I guess one has to set the scope USB option to PC.
The manual magically has the installer finding the drivers from thin air -- assuming UltraSigma is installed.
The fog is thick right now. ....
Brian
Offline Sparky
« Reply #1647 on: August 07, 2013, 02:05:18 am »
DS2000 series owners check your heat sink clips!
After using my new DS2072 for several days.  I noticed a rattling sound when I moved it.  Having heard of this clip retainer issue, I decided to investigate, but didn't want to void the warranty.  Luckily the heatsinks and clips can all be seen from the side ventilation holes.   I found on clip and one retainer were missing.  After lots of shaking, I was able to get both of the missing parts position by the ventilation holes and pulled them out with a tweezers.
It appears the retaining loop was soldered but not good enough for the heavy spring tension on it.
<snip>
After a long absence from posting in this favorite thread, I'm back!  I wish I had more time to post here, but for now just a cautionary note...
I've just experienced the same issue as martinv describes above.  I've been using my scope quite a bit recently, and aside from it warming up, there have been some very hot days in SoCal recently.  I was working and all of a sudden heard a loud metallic clank sound.  I had no idea where it came from, but today when I moved my scope I heard a rattle inside and recalled this heat sink clip issue.
I followed Mike's YouTube video to circumvent the warranty sticker, and opened up the unit.  Sure enough the spring was not in place.  I could not find the retaining clip; presumably it fell out when I was opening up the unit.  I believe the metallic clunk I heard was the retention clip getting pulled out and hitting the power supply cover.
See attached pic (warning: very high res!).
Just wanted to post a reminder that this is something to be on the look out for if you hear rattling in your scope!  Obviously not good to have metal pieces loose around in there...
Take care folks!
Offline martinv
    • mvforum
« Reply #1648 on: August 07, 2013, 03:24:46 am »
Take care folks!
Check the fan.  On my scope one of the loose parts stuck to the fan motor and was held there by the motor magnets so shaking didn't dislodge it.
« Reply #1649 on: August 07, 2013, 04:54:49 am »
Very stupid to rely on the solder alone to hold it in the board. At the least I would make a new one out of a paper clip cut in half, pushed through the hole and bent over on the underside before soldering back in the hole.
