I've been using my DS4024 for 8 months now and this evening, after only being on for an hour, the horizontal scale control stopped working. I can press the hated AUTO button, and it will set the timing properly on a test signal, but I can't change the setting manually.
I tried the two methods for resetting to factory default and disconnected the power for a while, but no luck.
The system info indicates the outlet temperature as 35.5 C, room ambient is 22.7 C. 35.5 doesn't seem particularly warm. I haven't made any changes in my bench layout, etc for months... it just stopped working.
Has anyone experienced anything similar?
