Tek P6150 is a low capacitance Z0 probe - 500ohm input impedance when terminated at the scope with 50ohms (thus is a 10x probe), and has 9GHz BW. The same probe has "feedthrough" tips which basically make it simply an extension of the coax.
Tek P6158 is a 20x probe, thus a 1K input impedance. 3GHz BW
Both of these are current products from Tek.
If you look used, you may also find things like the:
P6057, 100x 5Kohm 1.4GHz
P6056, 10x, 500ohm, 3GHz.
