Just recently purchased this meter from Amazon and while trying to measure electrolytic caps at 120Hz (i.e. 1000 uF & 2200 uF), I'm unable to select the Q-factor, ESR or Phase Angle. Only the default dissipation factor is provided and the meter beeps twice at me when pressing the button which tells me it's a non-functional parameter when it should be (I think).
However, if I cycle to inductance, I'm then able to select these factors (Q, ESR, theta) or if I cycle through the LCR and back to C measurement, I can THEN select those parameters with no issue.
Just wondering if I'm the only one experiencing this bizarre behavior. Thanks.
