I noticed I needed a version of the original Feeltech software installed on the machine before Fremens would run ,I had been trying out the latest FY6900 version pc software ,maybe this caused the issues I am seeing , I wonder is there a particular version of the Feeltech pc software I should be using for maximum compatibillity to Fremen's FP code ,
I also saw the software Yves created for his Fy3224s ,theres several features that looks very usefull , both to the radio enthusiast which its designed for ,but also would be very helpful for programming test tones or sweeps for audio or any other test purpose that comes to mind . The programable buttons to trigger arb waveforms from memory could almost turn the unit into the equivalent of a sampler ,might be of use to those who are looking to incorporate an arb gen in a musical context .
I tried a trial version of Ni labview to display the .VI file included with some of the Feeltech software packages , seems to make an attempt to copy the controls of the unit on screen but the labels are garbled charachters ,there appears to be a control element missing from the Feeltech VI file as well.
I did also see RHB's post about the Fy6600 WSPR transmitter , the author of the article did create a basic VB code for control of the FY6600, so thats another thing Id like to try out.
I did have another think about the double button press being required to select channel and mute/unmute , maybe a nice idea would be when you initially depress the channel 1 or 2 button have it select that channel to top if its not there already ,then let the unlatching of the button send the command to mute or unmute as required , now only a single press (and release) covers both functions , it only logical captain Fremen
Many thanks for all the efforts .
