It's not working!
I stared at the wires on Fremen67's foto's and PDF diagram, checked, double-checked, and its not working.
Symptoms:
- Both LED's on the bluepill are on
- No signal on the channels
- PC does see the COM10 connecting on USB
- PC software does work on COM10 with original FB
- PC software tells me nothing connected on the PORT with bluepill
So, I stared at the wires for a while. Unfortunately my wires are not the same rainbow as fremen's, but I tried to match them.
And also my bluepill has its headers on the other side of the board, so you have to think mirrored.
But still, I am pretty sure they are all correct.
Someone else wants to stare at my wires for a while, and point out where I went stupid?
Thanks, photo's attached.
(Note the white-gray on the 4-pin is unclear, because the white teared a strip of black along, making it also gray-ish, and the gray is reflecting light, making it also white-ish. And I have two red's. sorry, but so does Fremen67)
