@Fremen67: not wanting to push, but do you have any homework for me yet? My ST-Link clones arrived yesterday and are upgraded to the latest firmware. So time to flash these units ![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I had a busy week at work. It seems it's always like that when you want to take some days off
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I get stucked in my tests with the Feeltech PC Software. I though it would last longer without any modification but I was too optimistic...
When you type 123.45 Hz, it sends 1 then 12 than 123 then .... Hard to trigger anything correctly when debugging...
So long story short: I made some modifications to the PC Software:
- Add an input box to handle more easily inputs
- Remove all the amplitude & offset modifications the software was doing (the FP already handles that)
- Read back of parameters that the FP could change (Amplitude & Offset)
- Read back of CH2 synchronized parameters when changing CH1 parameters
- Add Synchrone Reads & Writes
- fixed the regional setting issue with "," & "."
- Add a Refresh button, just in case you modify things directly on the FG
- modified the display setting...
The source posted by feeltech was not the latest as you will see (mainly arbs handling differences) but it doesn't matter at the moment
If you already installed the original Feeltach software, you just have to copy and launch the modified one.
Could some of you guys try it ?
Now that the parameters are read from FG, I noticed that negative offset are not sent correctly by the FP. It is sending out of range values. I just display 0 in the case.
So I can go back to FP firmware now
![Fighting :box:](https://www.eevblog.com/forum/Smileys/default/fighting0030.gif)
Edit: Oups! Wrong file. OK now
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
