Im still waiting on my unit to arrive .
For the purposes of experimentation and learning Ive also sent out for one of the DSO138's , contains a similar STM32 type controler chip to the FY .There is open source software available for the DSO which allows you to access an extra analog input and two digital logic inputs on that board, and also a few mods to reduce the very noisey input stage . its also a simple matter to add a rotary encoder
https://github.com/ardyesp/DLO-138Seeing as its mostly audio I do , this unit will make a handy tool to have for a mobile test up.
I bought a second spare perspex case and I intend to house a battery/chg ,proper analog +- rails ,and a discrete op amp based 2nd analog audio mic/line input.
Could a dso130 board be used as a controller for the FY6600 main board ?
only the software and the push buttons would need to be added .
It seems from what ive read that we can control the main board of the FY6600 remotely with the correct usb interface .
Would it make sense to try and figure out a way to make a cheap new front panel or how about replacing the controller chip on the FY front panel with whats on the DSO board ,then putting together our own software interface ,what about the JTS front panel code it looks very similar too
Anyway there my ideas ,hopefully theres inspiration in there somewhere to get the ball rolling again .
