Apologise for the separate thread about this and appreciate there lots on here about this, I just wanted some clarification
Is it ok the fit an IEC panel socket and run a ground cable to the BNC`s to eliminate the AC leakage issue , as this seems an easy fix.
Will this still be ok to use with my oscillorscope, looking for the easiest safest fix please
thanks
Gary
