Author Topic: GW-Instek AFG-2125 - White Noise?  (Read 723 times)
Offline DGP750Topic starter
« on: June 09, 2020, 03:13:43 pm »
Hopefully someone with greater knowledge cas help me?
I have looked in the manual but cannot find the answer...
Simply, can I get this Function Generator to produce White and/or Pink noise?
I see the, "Noise" as a function and can select it but i'm stuck from there...
Offline Mr. Scram
  • Display aficionado
Re: GW-Instek AFG-2125 - White Noise?
« Reply #1 on: June 09, 2020, 03:17:29 pm »
Can you get other forms of actual output?
« Reply #2 on: June 09, 2020, 03:22:20 pm »
Hello, yes, I have been using it for calibrating an old reel to reel tape recorder with the sine waves but I would like to tune the equalization by ear using some noise...
Offline DrG
« Reply #3 on: June 09, 2020, 04:28:37 pm »
Search for gw instek afg-2125 manual in "the google".
Find https://www.phys.uconn.edu/~eyler/phys3150/R/Instek%20AFG-21xx%20user%20manual.pdf
Search for "noise" in the manual. Note wave form selection starting on page 36 (apparently you are already at that point - but including the link might encourage more knowledgeable people to weigh in - see below)). Futz with it for a while and pay particular attention to things like "The modulation, FSK, sweep and counter functions must be disabled before a standard waveform can be output." Go back to page 8 and make sure that all your settings are consistent with those limitations.
Wait for someone who is smarter than me to give you the right answer.
- Invest in science - it pays big dividends. -
