Author Topic: Fast accurate measuring resistance ?  (Read 5512 times)
Offline JanJansenTopic starter
Re: Fast accurate measuring resistance ?
« Reply #25 on: July 29, 2018, 01:48:03 pm »
It looks also complicated, and if i take a look at the youtube movie, i would have short circuit with a 2 ohm resistor.
No i just want to measure ohms not volts, else they should have build that into the multimeter.
For now i have my sets of 17 resistors, a whole lot, need to solder those first,
by the time i need to measure more resistors i expect a aneng meter with 5 digits for 10 euro shipped on ebay.
The 17 resistors are for a voltage controlled oscillator digital to analog converter.
Every synthesizer voice needs 17 resistors, here i made a new topic about the resistors what i dont understand :
https://www.eevblog.com/forum/projects/2-equal-resistors-is-not-the-same-as-1/
aliexpress parachute
« Reply #26 on: July 29, 2018, 03:15:56 pm »
By the way : some shop dont sell hioki dt4282 anymore, so its old meter,
i will see what model hioki releases next, intresting.
Offline Fungus
« Reply #27 on: July 29, 2018, 08:48:49 pm »
It's very old-school construction inside - surface mount but not much integration - lots of 74XX logic and stuff.
Doesn't make it worth any less though,  I say there's no better time to buy one!
« Last Edit: July 30, 2018, 01:25:54 am by Fungus »
Offline Synthtech
« Reply #28 on: July 29, 2018, 09:16:34 pm »
The Hioki DT4282 is very, very fast, it leaves my Keysight U1282a in the dust in terms of measurement speed and autoranging.
Offline Fungus
« Reply #29 on: July 30, 2018, 04:01:29 am »
It's also 0.03% accurate on the Ohms range and measures up to 600MOhm. I don't think there's a handheld DMM that can beat those specs.
« Reply #30 on: July 30, 2018, 02:16:06 pm »
When measuring capacity ?, are there also small values ?
Offline Fungus
« Reply #31 on: July 30, 2018, 03:02:17 pm »
Specs are here:
https://www.hioki.com/file/cmw/hdInstructionManual/93344/pdf/?action=browser
The lowest range is 1.0nF with 1100 counts at 1%+/- 20 so that's around 1pF resolution.
(ie. it beats the Fluke 87V and Brymen 869S here as well :popcorn:)
« Reply #32 on: July 30, 2018, 03:26:05 pm »
That is really a nice meter,
lazy politicians need to hurry the trade agreement.
Offline KaneTW
« Reply #33 on: July 30, 2018, 07:16:36 pm »
Customs duty is negligible, and VAT won't change. Just import it.
