Author Topic: Fluke 287 or 289 conditions inside  (Read 1374 times)
Offline Jon.CTopic starter
  • Country: ad
« on: December 11, 2022, 07:09:26 am »
Hi guys
what do you prefer
Fluke 287 completely new made in the USA, manufactured in February 2022 for €440
or
Fluke 289 manufactured in 2011 very little use (some small dirty stain)  made in the USA manufactured in 2011 for €440
for 100% electronic bench work
I already have 1  177 and 1  87V
Thank you so much
« Last Edit: December 11, 2022, 07:20:36 am by Jon.C »
Offline J-R
Re: Fluke 287 or 289 conditions inside
« Reply #1 on: December 11, 2022, 08:58:55 am »
My vote is the 287.  No supercap to worry about, will have a fresh calibration and of course is new.
Now what about the extra features with the 289?  Well, your 87V has the 1kHz filter, but the LoZ and 50 Ohm range could be handy in rare cases.  Personally I would use a 4-wire setup for low resistance measurements and LoZ can be handled easily enough with a simple resistor.
You said 100% electronics bench work, so the obvious question is why not a bench meter?
The following users thanked this post: Jon.C
  • Country: ad
« Reply #2 on: December 11, 2022, 09:56:31 am »
thanks for your answer
I had 2 bench multimeters and I sold them, too much space, I have kept a fun OWON XDM1041 that I am happy with.
I have a strange "attraction" for handheld multimeters and not for bench ones
The more I think about it, I think that 287 also convinces me...ummmh
Offline BeBuLamar
« Reply #3 on: December 11, 2022, 12:30:30 pm »
I have both of them. The 289 was made in 2016 and the 287 in 2022. Both are rarely used so cosmetically not different. I have them both so no decision but I think I would keep the 289 if I have to let 1 go.
Offline J-R
« Reply #4 on: December 12, 2022, 01:38:22 am »
With bench use in mind, will either come with calibration data?  When I purchased my new 287, it came with a verification report from Fluke, which is a great credibility booster.
Offline Arhigos
  • Country: gr
« Reply #5 on: December 12, 2022, 03:36:53 pm »
If you do 100% electronic bench work you probably will never need low-impedance and low-ohms functions. (both functions on this meter is for troubleshooting industrial electric motors)
