This meter seems to hit some key features and accuracy specifications. It would be nice to see ore about this, perhaps at least a tear down? How fast is the continuity test? What batteries does it use and how long per a set of batteries? Update rate and autoranging speed?
For such an expensive meter I would have expected more than 2500 data records.
Actually it does more data points through the logging software. I tested it to 40,000 points including Date & Time. The meter seemed to log all of them internally too. I will test the meter standalone with a logging rate of 1 sample per second and see what it tops out at.
The screen update speed is fast, I believe at it's fastest, it's like 25 updates per/s.
It uses 6 AA, so far after a few hours of testing, still at about 96%. It has a percentage of battery life in the Info screen. Very helpful, in addition to the bar graph battery meter.
The continuity test was quick, missed a few here and there, but I was snapping the leads pretty quick. I would say it had a 90% success rate.
Autorange update rate was respectable. I would say on the quicker side of most meters, I'll show this in my review video.
I am finally on some PTO over the next two weeks so I will have a bit of time to work on the video review. In the mean time if you have anymore questions, let me know. If you want me to do a specific test, also let me know.
