Author Topic: Cheap Meter required for NJM9210F chip to repair Digimess?  (Read 2008 times)
Offline Chris56000Topic starter
« on: October 24, 2017, 05:37:20 pm »
Hi!
I bought a cheapie Digimess DMM200:-
http://uk.farnell.com/digimess/dm200/multimeter-dig-bench-4000-count/dp/1076811
as "sold as seen" and unfortunately I found a problem with the DMM chip, a Japan Radio NJM9210FC, which appears to be jumping at random between ranges and several LCD segments gone!
Can anyone point me in the direction of cheaper models of DMM/clamp meters that use a '9210FC DMM chip please?
I got a set of circuit-diagrams for the Digimess from the seller and I've got the chip datasheet saved and there's good IR desoldering-tackle at work I can use, so it's just a matter of another chip!
Suggestions, anyone, please?
PS!
Is there another type of DMM chip likely to be compatible with the LCD used with the '9210 or would I have to get a new LCD panel to match another DMM chip design - I believe these things are multiplex-drive!
Chris Williams
« Last Edit: October 24, 2017, 07:34:16 pm by Chris56000 »
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline CJay
Re: Cheap Meter required for NJM9210F chip to repair Digimess?
« Reply #1 on: October 24, 2017, 06:13:15 pm »
Tektronix DM254?
Thought not...
However if you mean NJU9210F
https://www.aliexpress.com/item/Single-chip-digital-multimeter-IC-NJU9210FC-NJU9210/32474123033.html
Oh and those Digimess schematics wouldbe nice to see as well
« Reply #2 on: October 24, 2017, 06:17:13 pm »
Hi!
My apologies - it IS NJU9210FC I should have said!
I'll post the two pages of circuit I got when I can find them!
Chris Williams
PS!
Ali Express says this device is no longer available! - is there known to be a pin-compatible equivalent?
« Last Edit: October 24, 2017, 06:22:47 pm by Chris56000 »
Offline CJay
« Reply #3 on: October 24, 2017, 06:32:01 pm »
« Reply #4 on: October 24, 2017, 07:29:00 pm »
I have seen this:-
https://www.ebay.com/itm/NJU9210FC1C-00-QFP-3-3-4-DIGIT-SINGLE-CHIP-/361893332683?epid=1232813840&hash=item54428606cb:g:KL4AAOxyUrZS8OMi
but considering the very low price of some 334 - digit Chinese DMM's it's a bit on the pricey side for just the chip on it's own - surely Cryustek, etc., have done one the same or second-sourced the '9210 they seem to copy everything else, failing that there must be a cheap dmm I can scavenge for one?
Chris Williams
Offline retiredcaps
« Reply #5 on: October 24, 2017, 07:56:02 pm »
NJU9210FC is cheaper on aliexpress.  Starts at $24 USD + free shipping.
« Reply #6 on: October 24, 2017, 08:58:53 pm »
Hi!
I had another look on Ali Express - I don't know why the previous link turned up "no longer available" - I did find one for $24.00 (£18.37 approx sterling!) which is much more reasonable, so I've ordered one!
I'll post the tear-down and repair along with the schematics when the chip arrives, but before I attempt to fit another IC I'll service the PCB and all the voltage-regulators, smoothing capacitors, control/switching transistors, etc., etc., first!
Another project hopefully rescued from the dead - DM200s are £135 - £139.99 on Farnell or SJ Electronics!
Pic on the front of the manual:-
http://www.digimessinstruments.co.uk/manuals/english/mdm200engandger.pdf
Chris Williams
« Reply #7 on: October 26, 2017, 01:05:35 am »
PS!
This meter uses those Chinese staple fare, 8050s and 8550s as switching and control transistors – would locally–obtained BC182L/BC212L series devices do for servicing purposes?
Chris Williams
Offline CJay
« Reply #8 on: October 26, 2017, 06:21:38 am »
The 8050 and 8550 aren't expensive or hard to get, BC182/212 are a fifth the Ic, maybe BC327/337 might be better alternatives...
