Author Topic: Excel - Visual Basic - Tektronix data transfer via USB  (Read 6362 times)
Offline JesterTopic starter
« on: October 02, 2016, 12:52:11 am »
I'm attempting to talk with various instruments (tektronix, Agilent etc.) using VB in excel, using this as a starting point:
I have no problem communicating with the scope using the Tektronix excel add-in, to send and receive data, however the
Agilent VB code hangs during initialization.  I want to be able to communicate with other instruments so need a more
generic and flexible method, so I'm giving VB a try.
Using the Agilent code in the spreadsheet (2nd version below), I'm getting the following error when I click the Start button "An IO error occured: HRESULT =
80040011"  This code appears to be a "OLE_E_CANTCONVERT code meaning Not able to convert object.
In the Agilent/Youtube example shown in the video the init code is as follows:
Public Sub Intialize_Click()
On Error GoTo ioError
    instrAddress = Range("B4").Value
    Set ioMgr = New VisaComLib.ResourceManager
    Set instrAny = New VisaComLib.FormattedIO488
    Set instrAny.IO = ioMgr.Open(instrAddress)
    Exit Sub
ioError:
    MsgBox "An IO error occured:" & vbCrLf & Err.Description
End Sub
and the code in the supplied spreadsheet is slightly different:
    Set instrAny.IO = ioMgr.Open("DMM3")
    Exit Sub
ioError:
End Sub
The 3rd Set instruction is the one causing the error.
The 2nd version creates the HRESULT = 80040011 error, and the first version, causes excel to outright crash requiring a restart.
Does anyone have any insight or have experience communicating with an USB based Tektronix instrument from
excel using VB?
The excel file is available here:  https://community.keysight.com/thread/21917
Offline Jeff_Birt
Re: Excel - Visual Basic - Tektronix data transfer via USB
« Reply #1 on: October 02, 2016, 02:52:26 am »
The third instruction takes a argument that is the device address. The string "DMM3" can be converted to an understandable address. The variable 'instAddress' is probably not initialized, that is set to a real address, so it is causing an error.
« Reply #2 on: October 02, 2016, 03:34:44 am »
I changed:
Set instrAny.IO = ioMgr.Open("DMM3") to Set instrAny.IO = ioMgr.Open("USBInstrument1") and it now works
USBInstrument1 is the VISA Alias from the Keysight connection expert.
Thanks for your help
Online PA0PBZ
« Reply #3 on: October 02, 2016, 10:21:47 am »
Did you notice that the instrument address is pasted in cell B4 on the spreadsheet?
After that it is read by the VB program here:
Then the variable instrAddress is used to open the connection.
So if you put "USBInstrument1" in cell B4 the example should work unmodified.
