thought I share my 121GW bench stand design in case others might find it useful. I wanted the angle a little lower then the original build in stand and since I am almost exclusively use it on the bench I also wanted it a bit wider to prevent accidental fall over. Have to add some rubber pads to the bottom to prevent it from slipping around but should be fine then.
Thingiverse link:
https://www.thingiverse.com/thing:3862923Fusion 360 link:
https://a360.co/31q8WmWHave FuN!
Jan P.
