I need help with finding out a program function for measuring pulse jitter using a Rigol DHO800/900 series scope.
And present it with a measurement value of some sort, that the SCPI programming can spit out to the computer.
The measurement I wanna do is quite simple to do manually in persistence mode.
Checking pulse jitter of a positive signal CH1 compared to Trigger signal CH4 generated from a trigg generator. (5V pulse trig signal, 100hz)
The jitter I expect is somewhere around 5ns.
I would like to have it presented like a standard deviation, just a value I could print out.
If the DHO800/900 can't do it, I might need another scope that can.
Best regard
