Author Topic: Encoder or hall sensor for X-NUCLEO-IHM16M1(STM32 P-NUCLEO-IHM03 pack) ?  (Read 905 times)
Offline cadenaTopic starter
Hi everyone,
I am interested in buying a P-NUCLEO-IHM03 motor control pack but I would need to find, preferably, encoder or, at least, Hall sensors I can use with the  X-NUCLEO-IHM16M1 and test the rotary speed of the motor. Could someone please recommend me sensors that work fine with this board ? Thanks in advance.
« Last Edit: March 30, 2020, 10:57:40 am by cadena »
Offline thatguy1988
  • Country: il
Many motors include built in encoders. Connecting an encoder adds to the length of the shaft and requires accurate fitting. If you do not have the option of purchasing a motor with a built in encoder then I would go for the Hall sensor. I have used them many time to great effect and they are very cheap. Keep in mind that:
a) Hall sensors only sense ferrous (e.g. steel) targets, they will not sense aluminum
b) To sense a ferrous but non-magnetic target the hall sensor must include a built in magnet. Many hall sensors, include all of the hall effect 'electronic chips' will only measure a magnetic target.
Information about hall sensors
https://thesensorshack.com/sensors/hall-effect-proximity-sensor/
Hall sensor for ferrous targets
https://www.amazon.com/Twidec-Proximity-Inductive-NO%EF%BC%88Normally-NJK-5002C/dp/B07P1GKQRM/ref=sr_1_7?dchild=1&keywords=hall+effect+sensor&qid=1586015303&sr=8-7
