HostID: ED47F876
Quote from: evgar on April 02, 2024, 05:14:58 amHostID: ED47F876Here you go, let us know if it worked:1D7 81E4A5AD98B8B7B 12A3705847E5B7K 3D6D452D31F0BAA 00C0B1A52F18
Check the hardware options, if the demodulator board has been recognized properly.BAA is the plugin board with the "Ext Video In" and "Ext Video Out" BNC connectors. Part number E4401-60082.
Look at this guide: https://www.keysight.com/us/en/assets/9018-04279/installation-guides/9018-04279.pdfIt says that you need board E4401-60408 for FM demodulation.
Please tell me who can generate the code.
Quote from: Aigars535 on April 05, 2024, 10:54:33 amPlease tell me who can generate the code.Did you add the HW options yourself?According to the installation instructions, the BAA should be in slot 3 or slot 4. (page 12)https://www.keysight.com/us/en/assets/9018-04279/installation-guides/9018-04279.pdf
I have a E4402B, Modle:E4402B ESA-E, Host ID: 718002B1
Thanks! Dear PA0PBZ1DR 28666F68E30F1DS 27647069DD121D5 05A8928B21F0UKB AEE3A6A3C0BE1D6 04AE938C2BEBThese can work good!!!but 226 can not work, I don't know if I need anything else :'(,Maybe it needs to be install software.best regards!73!BH1ARE
