Author Topic: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B  (Read 108316 times)
Online PA0PBZ
Re: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B
« Reply #375 on: November 23, 2023, 03:59:05 pm »
I would be VERY happy to check this if somebody could generate the keys :-)
What model are you talking about, E440X or E444X?
Offline bonf
« Reply #376 on: November 23, 2023, 05:59:56 pm »
I've got a E4440A. roxbox said they have the same flex-lm data, so I would love to try it out.
added: I looked at the E4406A bin and the E4440A and found the flexlm structure,
the data is the same for both so I would think that the keys and seeds for the E4406A would work with the E444xA  specans.
Offline memogara
« Reply #377 on: November 23, 2023, 06:11:01 pm »
Thank you for your link. Apparently this problem was brought up to Keysight and they answered:
https://edadocs.software.keysight.com/kkbopen/i-ve-upgraded-my-esa-with-option-1dr-narrow-resolution-bandwidths-yet-the-instrument-will-not-go-below-a-1-khz-bandwidth-why-is-this-589744737.html
I haven't tried it as I don't have a GPIB-USB. I will acquire one and try.
Online PA0PBZ
« Reply #378 on: November 23, 2023, 08:34:02 pm »
The structure of the license file is slightly different and that's what I need to feed into the license generator. Try this:
215 E3EDAD5542E0
219 B725D9815AD4
226 A527A5753FC2
233 F1B7B5594CBC
239 CBE3DB7F58B6
241 8B9AB05C4FD7
The following users thanked this post: bonf
Offline bonf
« Reply #379 on: November 24, 2023, 10:17:35 am »
Hi PA0PBZ,
I just tried it out, but it doesn't work  :'(
I'll got back through the thread and check how I might get the data out of the E4440A.
Thanks for helping me check this out!
Marc
Online PA0PBZ
« Reply #380 on: November 24, 2023, 10:25:11 am »
Do you have an active option so I can compare?
Offline hvdspeev
« Reply #381 on: November 24, 2023, 02:10:02 pm »
Hi PA0PBZ,
Did I not post correctly or miss a post? Wanted to make an additional request:
Could I please get the keys for 227, 252, BAC, BAH for HostID: DE229E3E
Thanks!
Online PA0PBZ
« Reply #382 on: November 24, 2023, 03:50:01 pm »
Well, you said 'maybe I should get' so I was just waiting for you to make up your mind!  ;)
Also, first time you asked for 229 and now it is 252, so I included both, no idea if they make sense.
227 5593B899D5E0
229 4397CAABB9EE
252 B63DAA03CCE8
BAC B2A883845AB7
BAH B99A7C7D4CBE
The following users thanked this post: hvdspeev
Offline bonf
« Reply #383 on: November 24, 2023, 06:41:48 pm »
Yes, the options are
122   1EECA67647DB
123   1FEEA5754DD8
202   9C78B75B49DC
210   DEF3B25A44DF
B7J   7B3FFAA67A53
BAF   4AAF60E8B0B1
Is there any other way I can help? Marc
Offline hvdspeev
« Reply #384 on: November 24, 2023, 06:43:31 pm »
Thanks PA0PBZ! They worked fine ;)
Sorry for the confusion, as I still needed to research the hardware. The 229 requires the modulation decode board that I'm almost certain I'll never locate. And the 252 is an EDGE adder tot he GSM capabilities, which I do have the hardware for...
Many thanks! You're peaking my interest in this eevblog and I'm hoping that I can return the favors :)
Online PA0PBZ
« Reply #385 on: November 24, 2023, 07:55:15 pm »
122   1EECA67647DB
123   1FEEA5754DD8
202   9C78B75B49DC
210   DEF3B25A44DF
B7J   7B3FFAA67A53
BAF   4AAF60E8B0B1
Hi Marc,
I generated the first 3 and they match, so I'm confident that I can generate the correct keys and at the same time puzzled why they don't work for you.
Here's the license file I generated, with the first 3 options you asked and the last 3 you provided. The last 3 match what you showed...
FEATURE 215 TMOMID01 1.0 permanent uncounted E3EDAD5542E0 \
HOSTID=HOSTNAME=84242774
FEATURE 219 TMOMID01 1.0 permanent uncounted B725D9815AD4 \
FEATURE 226 TMOMID01 1.0 permanent uncounted A527A5753FC2 \
FEATURE 122 TMOMID01 1.0 permanent uncounted 1EECA67647DB \
FEATURE 123 TMOMID01 1.0 permanent uncounted 1FEEA5754DD8 \
FEATURE 202 TMOMID01 1.0 permanent uncounted 9C78B75B49DC \
Offline bonf
« Reply #386 on: November 25, 2023, 09:21:21 am »
Hi PA0PBZ,
I stopped after 2 fails. It is possible that I got the keys wrong when I was copying from my mobile phone.
I'm away this weekend, will try again on Monday.
Thanks again,
Marc
Offline bonf
« Reply #387 on: November 27, 2023, 02:07:57 pm »
Sorry really stupid mistake from me - didn't enter in the option number when putting in the licence key.
Worked gread once I figured that out.
Thank you !!!
Online PA0PBZ
« Reply #388 on: November 27, 2023, 04:57:31 pm »
Thanks for letting me/us know and happy analyzing!
Online DeepLink
« Reply #389 on: February 05, 2024, 09:37:18 am »
Hi PA0PBZ
I have a challenge for you :-)
This time not an E4402B, but a N8973A Noise Figure Analyzer - which is basically the same
Host ID: 40377DD9
Option: 1D5 (the only option for the N8973A)
/Hans J
Online PA0PBZ
« Reply #390 on: February 05, 2024, 10:12:46 am »
Hans, try F99444618811
No idea if it works, let us know.
Online DeepLink
« Reply #391 on: February 08, 2024, 08:59:14 am »
Thanks
Will test tonight - and let you know
Online DeepLink
« Reply #392 on: February 09, 2024, 06:45:03 am »
No luck here - the 1D5 option is not upgradeable on the N8973A
Never mind - I can always use the analyzer with an external 10 MHz reference
« Last Edit: February 12, 2024, 12:51:58 pm by DeepLink »
Offline 4x6uj
« Reply #393 on: February 19, 2024, 01:51:51 pm »
In my E4407B had to replace the A4 CPU board, desoldered and replaced the eeprom to keep my serial # but lost my options which were 1D6, 1DR, A4H, AYX, BAA, AYZ.
In addition, I would really appreciate it if you could help me enable a few extra ones: 219, 226, 229 and J36.
My serial is US40241687 and Host ID is: 4AF673B0
BR, 73
Serge
Online PA0PBZ
« Reply #394 on: February 19, 2024, 03:25:50 pm »
Hi Serge,
Try these and let us know:
1D6 EBB70CD48DA8
1DR 0F6FE8B045CC
A4H 1720AE56E1A6
AYX 2BD12FBF2077
BAA B051F9C9E287
AYZ 29D531C12475
219 ADA4E191423F
226 7CDDD387632F
229 6DDBE2964140
J36 B248C8946634
Offline 4x6uj
« Reply #395 on: February 19, 2024, 07:03:22 pm »
Great,
Thanks, works OK, appreciate the fast reply.
GL, 73
Serge
Offline 4x6uj
« Reply #396 on: February 20, 2024, 10:47:04 am »
PA0PBZ,
I have enabled all the options above and I have got a quasi-peak detector board for this E4407B analyzer.
Could you also generate the AYQ code? It would open-up extra detector modes in the menu.
As before, my serial is US40241687 and Host ID is: 4AF673B0
Thanks a bunch, 73
Serge
Online PA0PBZ
« Reply #397 on: February 20, 2024, 11:51:21 am »
AYQ   46BB14A42A72
The following users thanked this post: 4x6uj
Offline matthieu.e
« Reply #398 on: March 10, 2024, 06:17:46 pm »
Hello,
I have a E4402B serial number US39160343 with firmware A.01.02. I attached a picture of my configuration.
Should I upgrade my firmware ?
Can you generate the keys to unlock the options ? Thank you a lot.
Matthieu
Online PA0PBZ
« Reply #399 on: March 10, 2024, 09:31:23 pm »
Options are based on the HOSTID, if you can post that and the options you want I can help.
